new to mapserver - can't get map to display
Laura Neher
lneher at ON.PELMOREX.COM
Fri Oct 28 16:33:57 EDT 2005
Good Afternoon!
I am new to mapserver and Im having some problems getting my map to run. I
suspect the cause is either in the mapfile.map or the webpage.html or both
but I cant seem to figure out where it is.
I have two files that I would like to display. The first is a polygon file
of census areas that I would like to class based on population density. The
second is road features. I expect to be adding more to this but Im just
trying to get a good start. Below are my mapfile.map and webpage.html
files. Any assistance on what Im missing would be greatly appreciated.
Thanks!
Laura
MAPFILE.map
# Start of map file
MAP
NAME MyMap
STATUS ON
SIZE 600 450
# Map extent from ArcMAP dialog "Date Frame Properties > Data Frame"
EXTENT -81.77192 46.095211 -80.262369 47.068479
UNITS DD
SHAPEPATH "myData"
TEMPLATEPATTERN "webpage"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
# Projection definition
# In most cases, MapServer also works without a detailed definition
# PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
# END
# Start of reference map
# A full extent image needs to be exported from ArcMap
# ("File > Export Map... > *.PNG")
# The size of this image can be changed with an image editing program
REFERENCE
# Name of the image file as you saved it
# Extent information from ArcMap dialog "Date Frame Properties > Data
Frame"
# The current size of the image in pixels (see graphics program)
SIZE 207 196
STATUS ON
MINBOXSIZE 5
MAXBOXSIZE 100
COLOR -1 -1 -1
OUTLINECOLOR 128 0 0
MARKERSIZE 8
MARKER 'star'
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 2
TRANSPARENT TRUE
STATUS ON
END
# Start of layer definitions
LAYER
# This layer name has to be identical to the Shapefile name for the
layer
# (this is a bug in MapServer)
NAME Sudbury_populationi
TYPE POLYGON
STATUS ON
# Shapefile name in folder "myData"
DATA Sudbury_populationi
# Five classes have been defined for population density
# Class 1:
CLASS
EXPRESSION (([Pop_DEN] > 0) AND ([Pop_DEN] < 45))
NAME "Population Density 5-44/sqkm"
STYLE
OUTLINECOLOR 110 110 110
COLOR 255 255 204
END
END
# Class 2:
CLASS
EXPRESSION (([Pop_DEN] > 44) AND ([Pop_DEN] < 407))
NAME "Population Density 45-406/sqkm"
STYLE
COLOR 194 230 154
END
END
# Class 3:
CLASS
EXPRESSION (([Pop_DEN] > 406) AND ([Pop_DEN] < 819))
NAME "Population Density 407-818/sqkm"
STYLE
COLOR 121 199 123
END
END
# Class 4:
CLASS
EXPRESSION (([Pop_DEN] > 818) AND ([Pop_DEN] < 1606))
NAME "Population Density 819-1605/sqkm"
STYLE
COLOR 49 163 83
END
END
# Class 5:
CLASS
EXPRESSION ([Pop_DEN] < 1605)
NAME "Population Density 1606-2533/sqkm"
STYLE
COLOR 0 105 56
END
END
END
LAYER
layer
NAME Major_roads
# Filename in folder "myData"
DATA Major_roads
TYPE LINE
STATUS ON
# Only one class:
CLASS
NAME Name
STYLE
COLOR 255 0 0
END
END
TOLERANCE 3
END
END
WEBPAGE.HTML
<html>
<head>
<title>MapServer - Sudbury Population Density</title>
</head>
<body bgcolor="#ffffff">
<!-- Heading: -->
<center><h1>MapServer - Sudbury Population Density</h1></center>
<!-- Form for the initialization: -->
<p>
<form name="demo" method="GET" action="/cgi-bin/mapserv.exe"
onSubmit="submit_form()">
<input type="hidden" name="layer" value="Sudbury_populationi">
<input type="hidden" name="layer" value="Major_roads">
<input type="hidden" name="zoomsize" value=2>
<input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
<input type="hidden" name="map_web_imagepath" value="C:\www\tmp\">
<input type="hidden" name="map_web_imageurl"
value="http://herodot.geog.utoronto.ca/tmp/">
<input type="hidden" name="map_web_template" value="webpage.html">
<!-- Edit these two hidden variables: -->
<input type="hidden" name="map"
value="C:\www\users\m9050NeL\mapfile.map">
<input type="hidden" name="root" value="/users/m9050NeL">
<input type="submit" value="Initialize">
</form>
</p>
<hr>
<form method="GET" action="[program]" name="mapserv">
<center>
<table border="0" cellspacing="0" cellpadding="4">
<tr>
<!-- Map area: -->
<td valign="top" align="center">
<table width="390" border="0" cellspacing="0" cellpadding="4"
align="center" bgcolor="#666666">
<tr>
<td align="center"><input type="image" name="img" src="[img]"
width="600" height="450" border="0" alt="This is the map."></td>
</tr>
<tr><td bgcolor="#666666">
<img title="scalebar (km)" alt="scalebar (km)" src="[scalebar]">
</td></tr>
</table>
</td>
<!-- Navigation/explanation area: -->
<td valign="top" bgcolor="#ffffff">
<table cellpadding="5" cellspacing="0" border="0" bgcolor="#ffffff">
<tr><td>
<center><input type="submit" value="Refresh"></center>
<!-- Layer selection: -->
<p>
<b>Select Layers to Display: </b><br>
<select multiple name="layer" size=3>
<option value="sudbury_populationi" [Pop_DEN]> Population Density
<option value="Major_roads" [Name]> Major Roads
</select>
<!-- Zooming: -->
<p>
Zoom In <input type=radio name=zoomdir value=1 [zoomdir_1_check]>
Pan <input type=radio name=zoomdir value=0 [zoomdir_0_check]>
Zoom Out <input type=radio name=zoomdir value=-1 [zoomdir_-1_check]>
<p>
Zoom Size <input type=text name=zoomsize size=4 value=[zoomsize]>
<p>
<!-- Legend: -->
<font size=+1><b>Legend</b></font><br><hr>
<img src="[legend]"><hr>
<p>
<!-- Reference map: -->
<center><input name="ref" type="image" src="[ref]"
border="0"></center>
</td></tr></table>
</td></tr>
</table>
</center>
<!-- Hidden values: -->
<input type="hidden" name="mode" value="browse" checked>
<input type="hidden" name="imgxy" value="[center]">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="root" value="[root]">
<input type="hidden" name="savequery" value="true">
<input type="hidden" name="program" value="[program]">
<input type="hidden" name="map_web_imagepath" value="[map_web_imagepath]">
<input type="hidden" name="map_web_imageurl" value="[map_web_imageurl]">
<input type="hidden" name="map_web_template" value="[map_web_template]">
</form>
<hr>
<!-- Some information for the user: -->
<p>This is a map of the Sudbury CMA region. It blah...</p>
</body>
</html>
