new to mapserver - map won't display!!
Laura Neher
lneher at ON.PELMOREX.COM
Fri Oct 28 16:47:02 EDT 2005
Good Afternoon!
I am new to mapserver and Im having some problems getting my map to run. I
suspect the cause is in the mapfile.map but I cant seem to figure out
where it is.
I have two files that I would like to display. The first is a polygon file
of census areas that I would like to class based on population density. The
second is road features. I expect to be adding more to this but Im just
trying to get a good start. Any assistance on what Im missing would be
greatly appreciated.
Thanks!
Laura
MAPFILE.map
# Start of map file
MAP
NAME MyMap
STATUS ON
SIZE 600 450
# Map extent from ArcMAP dialog "Date Frame Properties > Data Frame"
EXTENT -81.77192 46.095211 -80.262369 47.068479
UNITS DD
SHAPEPATH "myData"
TEMPLATEPATTERN "webpage"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
# Projection definition
# In most cases, MapServer also works without a detailed definition
# PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
# END
# Start of reference map
# A full extent image needs to be exported from ArcMap
# ("File > Export Map... > *.PNG")
# The size of this image can be changed with an image editing program
REFERENCE
# Name of the image file as you saved it
# Extent information from ArcMap dialog "Date Frame Properties > Data
Frame"
# The current size of the image in pixels (see graphics program)
SIZE 207 196
STATUS ON
MINBOXSIZE 5
MAXBOXSIZE 100
COLOR -1 -1 -1
OUTLINECOLOR 128 0 0
MARKERSIZE 8
MARKER 'star'
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 2
TRANSPARENT TRUE
STATUS ON
END
# Start of layer definitions
LAYER
# This layer name has to be identical to the Shapefile name for the
layer
# (this is a bug in MapServer)
NAME Sudbury_populationi
TYPE POLYGON
STATUS ON
# Shapefile name in folder "myData"
DATA Sudbury_populationi
# Five classes have been defined for population density
# Class 1:
CLASS
EXPRESSION (([Pop_DEN] > 0) AND ([Pop_DEN] < 45))
NAME "Population Density 5-44/sqkm"
STYLE
OUTLINECOLOR 110 110 110
COLOR 255 255 204
END
END
# Class 2:
CLASS
EXPRESSION (([Pop_DEN] > 44) AND ([Pop_DEN] < 407))
NAME "Population Density 45-406/sqkm"
STYLE
COLOR 194 230 154
END
END
# Class 3:
CLASS
EXPRESSION (([Pop_DEN] > 406) AND ([Pop_DEN] < 819))
NAME "Population Density 407-818/sqkm"
STYLE
COLOR 121 199 123
END
END
# Class 4:
CLASS
EXPRESSION (([Pop_DEN] > 818) AND ([Pop_DEN] < 1606))
NAME "Population Density 819-1605/sqkm"
STYLE
COLOR 49 163 83
END
END
# Class 5:
CLASS
EXPRESSION ([Pop_DEN] < 1605)
NAME "Population Density 1606-2533/sqkm"
STYLE
COLOR 0 105 56
END
END
END
LAYER
layer
NAME Major_roads
# Filename in folder "myData"
DATA Major_roads
TYPE LINE
STATUS ON
# Only one class:
CLASS
NAME Name
STYLE
COLOR 255 0 0
END
END
TOLERANCE 3
END
END
