Using WMS time dimension with rasters?
    Gerry Creager
    gerry.creager at TAMU.EDU
    Fri Oct 28 14:55:10 PDT 2005
I need to echo Jeroen's comments.  We also are heading toward needing
WCS time support in Mapserver.
We're looking at this for meteorological datasets: satellite and radar.
I don't have someone I can put on this right now but it's in the list of
things when funding comes available... with the obligatory lag for a
grad student to ask questions and come up to speed.
gerry
Jeroen Ticheler wrote:
> Hi!
> Happy to see this discussion and implementation progressing! This
> (seeing more clients & servers with time support in WMS)  is indeed
> very true. We are working to get temporal data online both as WMS and
> WCS. Having a good support for that in MapServer would be a real
> asset, and actually allow us to use MapServer also for these data sets.
> In fact, this also gets to the problem I faced so far while
> implementing this; One common Map file will not do to have both a WMS
> and WCS with time support running, they are slightly different in the
> way they have to be configured (the WCS needs special layer that
> gives an error when accessing the service as WMS, at least that is
> what I ran into when following the different WMS and WCS time examples).
> Are there plans to align the two services?
> Greetings,
> Jeroen
> On 26 Oct 2005, at 21:20, Jeff de La Beaujardiere wrote:
>>> Jeff Schmaltz wrote:
>>> But looking at Appendix B & C of the WMS 1.1.1 spec, it's not
>>> clear to me if this combining of multiple extents and extent types
>>> is legal?
>> Per Table C.1 of WMS 1.1.1, this is legal:
>> 2004-09-21/2004-09-25/P1D, 2004-09-29/2004-10-31/P1D
>> However, the example you gave with a single value in the middle of a
>> set of ranges is neither forbidden nor explicitly permitted:
>> 2004-09-21/2004-09-25/P1D, 2004-09-27, 2004-09-29/2004-10-31/P1D
>> (sorry about that ambiguity in the spec).
>> You would be better off making the middle one similar to the others:
>> 2004-09-21/2004-09-25/P1D, 2004-09-27/2004-09-27/P1D,
>> -Jeff DLB
>> Editor
>> P.S. Although time support in WMS clients and servers has
>> traditionally been poor,
>> I think we will see more of it as providers with interesting time-
>> dependent
>> datasets start putting them on line.
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020
FAX:  979.847.8578 Pager:  979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
More information about the MapServer-users
