generateSLD bug
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Mon Oct 31 15:53:23 EST 2005
I also entered a general bug 1511
(http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1511) that notes you
examples at the need to review or at least document the limitations.
Later,
Yewondwossen Assefa wrote:
> Hi There,
> The expression parsor will work if some rules are followed like
> appropriate brackets and spaces between operator and values. In your
> case here are the expressions that should give you a valid output:
> 1) EXPRESSION ([fieldname] > 20 AND [fieldname] <= 40)
> result : <ogc:Filter><AND>
> <ogc:PropertyIsGreaterThan><ogc:PropertyName>fieldname</ogc:PropertyName><ogc:Literal>20</ogc:Literal></ogc:PropertyIsGreaterThan>
> <ogc:PropertyIsLessThanOrEqualTo><ogc:PropertyName>fieldname</ogc:PropertyName><ogc:Literal>40</ogc:Literal></ogc:PropertyIsLessThanOrEqualTo></AND></ogc:Filter>
> 2) EXPRESSION ([fieldname] <= 40)
> <ogc:PropertyIsLessThanOrEqualTo><ogc:PropertyName>fieldname</ogc:PropertyName><ogc:Literal>40</ogc:Literal></ogc:PropertyIsLessThanOrEqualTo></ogc:Filter>
> Let me know if it works.
> Later,
> Stefanie Weykam wrote:
>> I don't know if this bug has been filed before:
>> generateSLD():
>> Some class expressions are not properly understood and create erroneous
>> filters in XML documents. It seems that not all logical operators are
>> recognised:
>> This expression fieldname >20 AND fieldname <=40
>> results in .. PropertyIsGreaterThan ... Literal 20
>> instead of IsBetween
>> and with this expression fieldname <=40
>> the Proterty line is completely missing
>> I have just upgraded from MapServer/MapScript4.4 to 4.6.1 and it is still
>> the same.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
