labeling with SLDs in MapServer
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Sat Apr 1 11:37:57 EST 2006
Hi Laura,
we use this functionality quite often, but I don't have access to the
intranet Wiki here so I cannot paste an example.
I'll try to do that on Monday.
Best regards,
Bart
Laura Díaz wrote:
> Hi all,
> i am trying to label a layer i have defined in my map file, it is a
> point shapefile layer, the SLD i am using is as follows:
> <StyledLayerDescriptor>
> <NamedLayer>
> <Name>hojas_label</Name>
> <UserStyle>
> <Name>default:hojas_label:COD10000</Name>
> <IsDefault>1</IsDefault>
> <FeatureTypeStyle>
> <Rule>
> <Name>labels</Name>
> <TextSymbolizer>
> <Label>
> <ogc:PropertyName>HOJAS10_ID
> </ogc:PropertyName>
> </Label>
> <Font>
> <CssParameter
> name="font-family">Serif</CssParameter>
> <CssParameter
> name="font-style">normal</CssParameter>
> <CssParameter
> name="font-weight">normal</CssParameter>
> <CssParameter
> name="font-size">12</CssParameter>
> <CssParameter
> name="font-color">#000000</CssParameter>
> </Font>
> <LabelPlacement>
> <LinePlacement>
> <PerpendicularOffset>above</PerpendicularOffset>
> <LineWidth>2.5</LineWidth>
> <Gap>5</Gap>
> </LinePlacement>
> </LabelPlacement>
> </TextSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> When i request a GetMap with this layer and using this SLD i get the
> message from Mapserver:
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named
> 'hojas_label'.
> msDBFGetItemIndex(): DBASE file error. Item 'PropertyName' not found.
> </ServiceException>
> </ServiceExceptionReport>
> i´ve checked out the name of the field i want to label, and it is
> correct, actually i did try with all the fields and i have the same
> problem, the layer is good as well because i can visualize it if i
> just don't use this SLD....
> Any ideas?
> thanks in advance,
> Laura
OSGIS, Open Source GIS
http://www.osgis.nl
