centering on the result of itemquery
Didrik Pinte
dpinte at ITAE.BE
Sun Apr 2 00:38:53 EST 2006
Le samedi 01 avril 2006 à 18:26 +0200, Didrik Pinte a écrit :
> Hi,
> i'm using the CGI interface to mapserver. I'm trying to get in one call
> a map centered on the result of a ITEMQUERY request.
> How is this possible ?
> Here is the working query i'm using at the moment :
> http://loclhost/cgi-bin/mapserv?map=/var/www/mapserver/csmap.map&mode=itemquery&layers=filling&scale=400000&mapxy=374974+1816035&mapsize=500+300&qlayer=selection&qstring=clientid%20=%20'T6_3137'&qitem=clientid
> Working fine but not centering on the result and displaying empty if the
> searched point is outside of the visible bounding box.
> Many thanks in advance for your help.
> Didrik
Here is the answer ;-)
adding MAPEXT=shapes to the query centers the query on the selected
shapes. The SCALE must be defined in order to do the extent computation.
! The searched map file must have all the searchable points in its
extent. Points outside of the extent cannot be searched. Is this a
normal behaviour ?
So the correct query string is the following :
http://localhost/cgi-bin/mapserv?map=/var/www/mapserver/csmap.map&mode=itemquery&layers=filling&mapsize=500+300&qlayer=selection&qstring=clientid%20=%20'T8_7185'&qitem=clientid&mapext=shapes&scale=400000
Didrik
Name: not available
Desc: Ceci est une partie de message
=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060402/4248f93d/attachment.bin
