labeling with SLDs in MapServer
Laura Díaz
laura.diaz at IVER.ES
Mon Apr 3 08:04:23 EDT 2006
Hi Bartje,
thanks for your answer.. i made the SLD work just changing
<Label>
<ogc:PropertyName>HOJAS10_ID
</ogc:PropertyName>
</Label>
for
<Label>
HOJAS10_ID
</Label>
in the Label tag, it appears in the documentation in that way, but it does not work, at
least in the mapserver i use 4.6.1.
> I don't think this is possible (I also briefly checked the source code
> and all the handlers use OWS_GML2).
> So if you want it, submit an enhancement request for it in bugzilla.
yes, that is a good suggestion, it is a useful functionality
> Btw, what happened to your C reading capabilities :-) ?
don't know... what happened? :-))
regards,
Laura
On 3 Apr 2006 at 7:18, Eijnden, B. van den (Bart) wrote:
> Laura,
> this works for us (Name is the layer name, Label is the column name):
> <StyledLayerDescriptor version='1.0.0'>
> <NamedLayer>
> <Name>NL-prov</Name>
> <UserStyle>
> <FeatureTypeStyle>
> <Rule>
> <TextSymbolizer>
> <Label>OMSCHR</Label>
> <Font>
> <CssParameter name='font-color'>#000000</CssParameter>
> <CssParameter name='font-family'>arial</CssParameter>
> <CssParameter name='font-size'>10</CssParameter>
> </Font>
> </TextSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> Van: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Bart van den Eijnden
> (OSGIS)
> Verzonden: zaterdag 1 april 2006 18:38
> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: Re: [UMN_MAPSERVER-USERS] labeling with SLDs in MapServer
> Hi Laura,
> we use this functionality quite often, but I don't have access to the
> intranet Wiki here so I cannot paste an example.
> I'll try to do that on Monday.
> Best regards,
> Bart
> Laura Díaz wrote:
> > Hi all,
> > i am trying to label a layer i have defined in my map file, it is a
> > point shapefile layer, the SLD i am using is as follows:
> > <StyledLayerDescriptor>
> > <NamedLayer>
> > <Name>hojas_label</Name>
> > <UserStyle>
> > <Name>default:hojas_label:COD10000</Name>
> > <IsDefault>1</IsDefault>
> > <FeatureTypeStyle>
> > <Rule>
> > <Name>labels</Name>
> > <TextSymbolizer>
> > <Label>
> > </ogc:PropertyName>
> > </Label>
> > <Font>
> <CssParameter
> > name="font-family">Serif</CssParameter>
> <CssParameter
> > name="font-style">normal</CssParameter>
> <CssParameter
> > name="font-weight">normal</CssParameter>
> <CssParameter
> > name="font-size">12</CssParameter>
> <CssParameter
> > name="font-color">#000000</CssParameter>
> > </Font>
> > <LabelPlacement>
> <LinePlacement>
> <PerpendicularOffset>above</PerpendicularOffset>
> <LineWidth>2.5</LineWidth>
> <Gap>5</Gap>
> </LinePlacement>
> > </LabelPlacement>
> > </TextSymbolizer>
> > </Rule>
> > </FeatureTypeStyle>
> > </UserStyle>
> > </NamedLayer>
> > When i request a GetMap with this layer and using this SLD i get the
> > message from Mapserver:
> > <ServiceExceptionReport version="1.1.1">
> > <ServiceException>
> > msDrawMap(): Image handling error. Failed to draw layer named
> > 'hojas_label'.
> > msDBFGetItemIndex(): DBASE file error. Item 'PropertyName' not found.
> > </ServiceException>
> > </ServiceExceptionReport>
> > i´ve checked out the name of the field i want to label, and it is
> > correct, actually i did try with all the fields and i have the same
> > problem, the layer is good as well because i can visualize it if i
> > just don't use this SLD....
> > Any ideas?
> > thanks in advance,
> > Laura
> OSGIS, Open Source GIS
> http://www.osgis.nl
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen.
> This message shall not constitute any rights or obligations.
> This message is intended solely for the addressee.
> If you have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this message
> is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060403/ae2e2273/attachment.html
