Bug in Mapserver-4.8.3
Doyon, Jean-Francois
Jean-Francois.Doyon at CCRS.NRCAN.GC.CA
Mon Apr 3 10:06:10 EDT 2006
Did you compile a new version of freetype for use with 4.8.3, or are both
versions linking agianst the exact same binary of the freetype library?
J.F.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of wbr
Sent: April 3, 2006 2:00 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Bug in Mapserver-4.8.3
Hi All,
i'm not sure if i had found a bug. We use a application with mapserver and a
lot of labeling of streets, citys and so on.
I think the labeldrawing in mapserver 4.8.3 is not correct, i have attached
2 pictures where you can see the difference on the cities Braunschweig and
Wolfsburg.
here the mapfile with the layer definition of cities.
LAYER
NAME staedte
TYPE POINT
STATUS DEFAULT
MINSCALE 200000
DATA std500_gk3
LABELITEM "STADT_NAME"
LABELCACHE on
Postlabelcache false
CLASSITEM 'STADT_BEV'
CLASS
expression /1/
NAME 'Städte > 1000000'
COLOR 0 0 0
SYMBOL 'full_circle'
SIZE 10
LABEL
POSITION LC
TYPE TRUETYPE
FONT arial-bold
COLOR 0 0 0
SIZE 12
ANTIALIAS TRUE
OUTLINECOLOR 255 255 255
PARTIALS true
END
END
CLASS
expression /3/
MAXSCALE 750000
name 'Städte > 250000'
color 0 0 0
symbol 'full_circle'
size 7
label
POSITION LC
TYPE TRUETYPE
FONT arial
COLOR 0 0 0
SIZE 9
ANTIALIAS TRUE
PARTIALS true
end
END
CLASS
expression /5/
MAXSCALE 500000
name 'Städte > 25000'
color 0 0 0
size 6
label
POSITION LC
TYPE TRUETYPE
FONT arial
COLOR 0 0 0
SIZE 7
ANTIALIAS TRUE
PARTIALS true
end
END
END
the labels with size less then 9 are correct ?!?
Can someone verify this ?
Thanks,
Wolfgang Brungert
T-Mobile Deutschland GmbH
Program and Budget Management
(TRPD13-D)
Roddestr. 12
48153 Münster
Phone: +49 251 977 4142
Fax: +49 251 977 4149
email: wolfgang.brungert at t-mobile.de
PGP Fingerprint: B3F8 D368 5EEF 3873 3C4F 423C 171E F217 7CA4 3467
