WCS maximum window size?
Frank Warmerdam
warmerdam at POBOX.COM
Wed Apr 5 21:42:33 EDT 2006
Jeroen Ticheler wrote:
> Hi,
> Is there a way to configure a WCS to only allow images with a maximum
> size (e.g. 1000*1000 pixels)? Or should this be handled in another manner?
> Thanks,
> Jeroen
Jeroen,
There is a "maximum size" parameter for mapserver that limits the largest
image that can be requested from mapserver. I believe it applies to WCS
as well, though I'm not actually sure about that.
The default value of the parameter is 2048, so no image larger than
2048 x 2048 could be requested. You can alter it with the MAXSIZE keyword
in your MAP section.
eg.
MAXSIZE 10000
(to allow up to 10000 x 10000 images).
If this parameter does not apply to WCS then I think we should consider it.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
