SLD / Point symbolizer & Size
Michael Schulz
mschulz at WEBGIS.DE
Thu Apr 6 09:09:04 EDT 2006
Hi Francois,
as long as you don't specify a symbolscale MapServer will do the
Size=MinSize=Maxsize thing. Did you set the layers sizeunits to pixel
(pixel is the default)?
Cheers, Michael
François Prunayre schrieb:
> Hi list,
> Using SLD and symbols, I get 2 differents behaviour using Mapserver &
> Geoserver. Differences is on point symbolizer and the size parameter.
> For example, using a png file of 20x20px
> http://sandre.eaufrance.fr/geo/sym/port.png
> in the following SLD for mapserver :
> _http://xml.sandre.eaufrance.fr/exist/Geo/sld/REPOM.xml_
> <http://sandre.eaufrance.fr/geoserver/data/generated/topp_REPOM.html>
> When I ask for 3 images (400x400px) for the REPOM layer at 3 differents
> scales, the symbol is getting bigger and bigger ... Size is set to 2.
> And units in the OGC SLD spec is defined as "The *Size *element gives
> the absolute size of the graphic in pixels encoded as a floating-point
> number."
> http://services.sandre.eaufrance.fr/geo/ouvrage?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-6,41,10,52&SRS=epsg:4326&SLD=http://xml.sandre.eaufrance.fr/exist/Geo/sld/REPOM.xml
> <http://services.sandre.eaufrance.fr/geo/ouvrage?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-6,41,10,52&SRS=epsg:4326&SLD=http://xml.sandre.eaufrance.fr/exist/Geo/sld/REPOM.xml>
> http://services.sandre.eaufrance.fr/geo/ouvrage?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-6,48,0,50&SRS=epsg:4326&SLD=http://xml.sandre.eaufrance.fr/exist/Geo/sld/REPOM.xml
> <http://services.sandre.eaufrance.fr/geo/ouvrage?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-6,48,0,50&SRS=epsg:4326&SLD=http://xml.sandre.eaufrance.fr/exist/Geo/sld/REPOM.xml>
> http://services.sandre.eaufrance.fr/geo/ouvrage?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-5,48,-4,49&SRS=epsg:4326&SLD=http://xml.sandre.eaufrance.fr/exist/Geo/sld/REPOM.xml
> <http://services.sandre.eaufrance.fr/geo/ouvrage?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-5,48,-4,49&SRS=epsg:4326&SLD=http://xml.sandre.eaufrance.fr/exist/Geo/sld/REPOM.xml>
> Using Geoserver with the same layers, when I ask for 3 images
> (400x400px) for the REPOM layer at 3 differents scales (same as previous
> query), the symbol is always the same size (15 as defined in the STYLES
> for geoserver).
> http://sandre.eaufrance.fr/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-6,41,10,52&SRS=epsg:4326&STYLES=REPOM&FORMAT=image/png
> <http://sandre.eaufrance.fr/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-6,41,10,52&SRS=epsg:4326&STYLES=REPOM&FORMAT=image/png>
> http://sandre.eaufrance.fr/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-6,48,0,50&SRS=epsg:4326&STYLES=REPOM&FORMAT=image/png
> http://sandre.eaufrance.fr/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-5,48,-4,49&SRS=epsg:4326&STYLES=REPOM&FORMAT=image/png
> <http://sandre.eaufrance.fr/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=REPOM&WIDTH=400&HEIGHT=400&BBOX=-5,48,-4,49&SRS=epsg:4326&STYLES=REPOM&FORMAT=image/png>
> Mapserver is setting the SIZE parameter in the class ... but maybe not
> MAXSIZE and MINSIZE. In that case default value for MAXSIZE and MINSIZE
> are used ? ... should we have SIZE=MAXSIZE=MINSIZE to have always the
> same size for the symbol.
> This behaviour also occurs using well know shape as "square", "circle",
> "triangle" ...
> Any ideas on how to get symbol always with the same size ? Anyone having
> the same behaviour ?
> Thanks for your help.
> Francois
> PS : Geoserver doesn't support SLD parameter in the URL for the time
> being so we have to define a style in Geoserver and the using keyword
> STYLES in the URL.
> Ce message a ete verifie par *MailScanner*
> <http://www.mailscanner.info/> pour des virus ou des polluriels et rien
> de suspect n'a ete trouve.
> Les donnees et renseignements contenus dans ce message sont personnels,
> confidentiels et privés.Toute publication, utilisation ou diffusion,
> meme partielle, doit etre autorisee.
> Any data and information contained in this electronic mail is personal,
> confidential and private. Any total or partial publication, use or
> distribution must be authorized.
Michael Schulz mschulz at webgis.de
in medias res Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66 Tel +49 (0)761 556959-5
79108 Freiburg Fax +49 (0)761 556959-6
www.webgis.de / www.zopecms.de
NEU ++ UMN MapServer Hosting ++ http://www.webgis.de ++ NEU
