Performance hints please
Ed McNierney
ed at TOPOZONE.COM
Thu Apr 6 09:28:30 EDT 2006
Stephen -
"The amount of geometry involved is so small, the bottleneck has to be
the raster processing"
That is a dangerous assumption. Retrieving a small amount of data from
a large, slow database server can take a long time - particularly if
you're re-establishing the connection each time.
Are you using pooled persistent connections to PostGIS with a FastCGI
MapServer?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Stephen Davies
Sent: Thursday, April 06, 2006 4:04 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Performance hints please
G'day all.
Does anybody have a howto on Mapserver performance enhancement?
My particular environment of interest is a relatively small set of
geometries in a PostGIS database and a collection of geotiff aerial
photography images onto which I overlay the geometries.
The geometries are fully indexed, relatively static and vacuum analyzed
every night.
One of the options that users have is to request a "movie" of up to 20
frames; each of which consists of a background raster plus up to about
five circular geometries, about five points and maybe ten other
lines/polygons.
the raster processing. The images are 2m/pixel and are typically 20 -
150 Mb each. The frame extents include most if not all of an image so
tiling does not seem relevant.
I have specified 80% JPEG as the output to minimise final image size and
this seems successful (at least in terms of size and hence download
time)
I am looking for ways to reduce the time taken in the image generation
phase.
TIA,
Stephen Davies
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
