Legend not showing up in IE
Dylan Beaudette
dylan.beaudette at GMAIL.COM
Fri Apr 7 13:00:08 EDT 2006
Interesting.
Fixed the empty color string.
I have been puzzling over the "document.layers" error on the javascript
console for a while now.
Looking into the source of the main landview application source file, i see a
couple references to document.layers:
function checkLegendControls(element) {
for (var i=0; i<element.length; i++) {
var maxscaleObj = eval("document.layers." + element[i].value +
"Maxscale");
var minscaleObj = eval("document.layers." + element[i].value +
"Minscale");
if (maxscaleObj) {
if (maxscaleObj.value < ms.getscale()) {
disableLegendControls(element[i]);
continue;
if (minscaleObj) {
if (minscaleObj.value > ms.getscale()) {
and it looks like this function is run from the postdraw() function with:
checkLegendControls(document.layers.foreground);
checkLegendControls(document.layers.background);
Note that I am not including a "layers=" string in my URL passed to the
mapserver CGI.
Cheers,
On Friday 07 April 2006 09:32 am, Andrew Krakowski wrote:
> My IE debugger complained about
> document.getElementById('survey_message').style.color = color;
> So perhaps make a default color to assign rather than an empty string.
> Also there are a couple JavaScript errors when you load the page in
> FireFox and the one that says "document.layers has no properties" leads
> me to suspect you are assigning or using a layer before it has data.
> Cheers!
> Andrew
> Dylan Beaudette wrote:
> > Greetings,
> > Our Landview-based DHTML mapserver application works quite well on nearly
> > every web browser _except_ IE...
> > Here is a link to a sample page, note that there should be a legend in
> > the upper left hand corner:
> > http://tinyurl.com/mjfxk
> > I have browsed through the javascript libraries included in the landview
> > application, but have yet to find any thing that might be related to the
> > missing legend. I have a sneaking suspicion that it has something to do
> > with how the DBOX container is implemented.
> > Any thoughts or suggestions would be greatly appreciated.
> > Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
