query by attributes on large datasets
    Skalski Artur - askals
    Artur.Skalski at ACXIOM.COM
    Tue Apr 11 23:54:35 PDT 2006
Hi All
I need to do query by attributes on quite large dataset, about 1 100 000 records (one Layer), I've all my data in Mapinfo Tab files, all works fine except when I do query by attributes on that large layer something crushes, I can see that HD is working for a while but then it stops and nothing happens, whole site needs to be reloaded to make it work again, I've got no idea if it's mapserver or php config problem (I'm using mapserver 4.6 with phpmapscript, php 5.0.5 and win IIS 5.0),
could You give me some advice what to do to make the search work?
Many thanks for any tip
best regards
Artur
The information contained in this communication is confidential, is
intended only for the use of the recipient named above, and may be legally
privileged.
If the reader of this message is not the intended recipient, you are
hereby notified that any dissemination, distribution or copying of this
communication is strictly prohibited.
If you have received this communication in error, please resend this
communication to the sender and delete the original message or any copy
of it from your computer system.
Thank You.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060412/1e846f63/attachment.htm>
More information about the MapServer-users
