Query wildcards
Xin
crazygecko at GMAIL.COM
Wed Apr 12 05:03:00 EDT 2006
Try
&qstring=('[KABELNAAM]'=/^RING.*/')
Remeber MapServer regular expressions are case sensitive. To do an case
insensitive search, you will need to manually alter the expression to
something like:
&qstring=('[KABELNAAM]'=/^(r|R)(i|I)(n|N)(g|G).*/')
Good luck.
Xin
On 10/04/06, Bart van den Eijnden (OSGIS) <bartvde at xs4all.nl> wrote:
> I haven't tried but maybe use qitem=KABELNAAM&qstring= /^Z.*/
> Best regards,
> Bart
> Jelmer Baas wrote:
> > Bart van den Eijnden wrote:
> >> You should use regex to get that behaviour, for instance LIKE Z*
> >> would be:
> >> EXPRESSION /^Z.*/
> > Awesome, thanks. Though, I have no clue how to put that in the query
> > below. Another bump in the right direction, please?
> > Sorry, but I'm not used to regex'es.
> >>> My current query is
> >>> &qstring=('[KABELNAAM]'='RING7')
> OSGIS, Open Source GIS
> http://www.osgis.nl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060412/99a4ae4d/attachment.html
