GeoTIFF source alpha/transparency: what's the best method?
Kirk Holbrook
kirk.holbrook at VERIZON.NET
Wed Apr 12 16:33:41 EDT 2006
I've been working to optimize my map that uses several large geoTIFFs
(over 500MB each).
I started out using Red (RGB 255 0 0) as the area to be transparent in
my TIFFs (since there is no true red in any of my TIFFs) and using
"OFFSITE 255 0 0" in each layer to make it transparent. It works well,
but when I use gdaladdo to add overviews to optimize my map, I get a lot
of red artifacts in the overviews. I've also set up a tileindex which is
helping immensely.
Is there a better way to handle transparency? I've got 24 bit TIFFs
(which I'd like to keep, rather than going to 8 bit). Note also that my
transparent areas are not necessarily rectangular -- there are a few odd
shapes.
Thanks a lot,
Kirk
