Java Mapscript - querybyattribut
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Thu Apr 13 11:18:39 EDT 2006
This is probably not related only to java mapscript, so please read on.
On 3/30/06, Oliver Wesp <wesp at gdv.com> wrote:
> Dear List,
> I' struggling with queryByAttributes on an attribute field with german
> umlauts using java mapscript.
> The odd thing is that the same thing works fine with php mapscript and
> when I use expressions in my mapfile. I'm using a shapefile as datasource.
Could someone of the other mapserver developers shed some light on this issue?
I have a clue to give: php mapscript is using a different regex
library and this explains why the match does not happen for Java
mapscript, while it does happen in php mapscript. If I am right also
the mapserver cgi should be affected and possibly all other mapscript
too.
It would be very interesting if someone could report on similar
experiences with the cgi-bin version of mapserver.
Thanks,
Umberto
> Here is what I do:
> layer.queryByAttributes(map,"KREIS_NAME", "/Südliche Weinstraße/",
> mapscriptConstants.MS_MULTIPLE);
> layer.open();
> System.out.println( "Result Count: " +layer.getNumResults() );
> layer.close();
> The result is always null while replacing the qstring with something
> that doesn't contain special characters (e.g.
> 'Mainz-Bingen') works fine.
> As noted above the following layer definition in a mapfile works fine
> LAYER
> NAME kreis
> STATUS DEFAULT
> TYPE polygon
> DATA "/tmp/subset"
> TEMPLATE "kreis.html"
> CLASSITEM KREIS_NAME
> CLASS
> NAME Boundary
> COLOR 128 128 0
> OUTLINECOLOR 0 0 0
> EXPRESSION /Südliche Weinstraße/
> END
> END
> but this does not:
> layer.setClassitem("KREIS_NAME");
> classObj cl = new classObj(layer);
> cl.setName("Classname");
> cl.setExpression("/Südliche Weinstraße/");
> I use Mapserver 4.8.1 on W2k, Tomcat 5.0.28.
> I can provide some sample data, just in case someone likes to reproduce.
> Any help is appreciated.
> best regards
> Oliver
> Dipl.-Geogr. Oliver Wesp
> Gesellschaft fuer geografische Datenverarbeitung
> Binger Strasse 49-51
> D-55218 Ingelheim
> fon: +49 6132 714818
> fax: +49 6132 714828
> http: www.gdv.com
