landview application and AJAX
    Steve Lime
    Steve.Lime at DNR.STATE.MN.US
    Mon Apr 17 15:04:55 PDT 2006
The order is predraw callback, then the object draw method and finally the postdraw callback.
The newer landview code (http://maps.dnr.state.mn.us/landview/experimental/landview.html)
uses a single draw callback so you can do whatever you want.
Steve
>>> Dylan Beaudette <dylan.beaudette at GMAIL.COM> 4/17/2006 3:47:34 PM >>>
Thanks for the pointers Steve,
In particular I was curious about the execution order, or a general concept of
how the Landview application works.
Thanks,
Dylan
On Monday 17 April 2006 12:57 pm, Steve Lime wrote:
> There is a member in the Mapserv object called 'options' that allows you to
> add arbitrary parameters to the URL passed to mapserver. You might try
> something like:
>   myMap.options = "&foo=" + foovar;
> Where 'foo' is the variable you're passing to MapServer and foovar is the
> javascript variable you filled via ajax/xmlhttp...
> Make sense?
> Steve
> >>> Dylan Beaudette <dylan.beaudette at GMAIL.COM> 4/17/2006 1:19:27 PM >>>
> Greetings,
> I have been working with the Landview DHTML interface to mapserver, and
> would like to include support for some additional asynchronous interaction
> with a database.
> Currently our application works like this:
> select a region --> generate URL based on selection --> mapserver
> application with arguments in URL --> interaction with mapserver
> application
> I have written some functions in javascript and PHP to perform a spatial
> query on a PostGIS database:
> mapserver application --> calculate extent center coordinates with JS -->
> AJAX style request to PHP function page --> data is returned to mapserver
> page and displayed
> this is being done in the postdraw() function found in the landview
> application.
> I am having trouble figuring out how to pass the results from the above
> function to the creation of the mapserver object such that this value is
> also passed to the mapfile.
> In particular, I am curious about when the following line from the landview
> application is executed:
> var ms = new Mapserv("main", the_mapfile,  ... );
> Any ideas on how to do this?
> Thanks!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
More information about the MapServer-users
