Java Mapscript - querybyattribut
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Apr 18 09:02:25 EDT 2006
Benedikt,
Thanks for you insight.
I am not a i18n or charsets guru but I believe that the encoding
mapserver expects deep in C code only depends on glibc which is
unicode compliant (at least on modern distros, dunno abot ye ol
slackware 3 box ;-) ). The behaviour is controlled by the LANG and
LC_* environment variables.
Please review my last post here which solved a similar issue:
http://thread.gmane.org/gmane.comp.gis.mapserver.user/19248/focus=19249
Best regards,
Umberto
On 4/18/06, listuser HH <listuser at herzsys.de> wrote:
> Benedikt Rothe wrote:
> >Hi
> >The C-Wrapper "mapscript_wrap.c" converts Java-Strings to
> >"char*" with the JNI-Function "GetStringUTFChars".
> >This UTF-8-byte-sequence is passed to the mapserver-kernel.
> >But mapserver-kernel expects an one-byte-encoding. (ISO-8859-1 or CP437
> >I wrote a JNI-sample-program to illustrate.
> >The sample-program converts to UTF-8, ISO-8859-1 and CP437.
> >On my Windows-Command-Prompt the CP437-result was correct.
> >I think mapscript_wrap.c has to do more than UTF-8-Conversion.
> >Benedikt
> Hi all,
> is there a way to do the converion in java dircetly?
> Thanks in advance
> Norbert
