Performance hints please
Frank Warmerdam
warmerdam at POBOX.COM
Wed Apr 19 09:35:15 EDT 2006
Stephen Davies wrote:
> Thanks for the feedback. I have been distracted by easter and other
> priorities and have only just got back to this question.
> Here is a sample explain output. I think it says that my DB structure is
> OK. (The statement is taken from a log of a mapserver session.)
> The biggest geometry table in this database has only 166 rows.
> I don't know whether the connection is persistent or not. How does
> mapserv manage connections?
Stephen,
Persistent connections are not important for PostGIS. Connection cost
for postgres is very modest. The situation is very different for
Oracle or any SDE fronted database.
> The TIFF rasters that I am using are included in their entirety. That
> is, the map extent is the same or bigger than the image. Are overviews
> still relevant in this context?
It depends how large the rasters are. If they are large then this is
exactly the circumstance in which overviews would help a lot. When I
say "if they are large" I really mean are they substantially higher
resolution then the map image you want to generate.
> What is the significance of the OID use? This table (and all others) has
> a proper unique key.
I'm afraid I don't know anything about this.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
