two attribute in labelitem
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri Apr 21 06:31:24 EDT 2006
You should use TEXT for that.
TEXT [string]
Static text to label features in this class with. This overrides
values obtained from the LABELTIEM. The string may be given as an
expression delimited using the ()'s. This allows you to concatenate
multiple attributes into a single label. For example:
([FIRSTNAME],[LASTNAME]).
See the MAP file reference:
http://mapserver.gis.umn.edu/docs/reference/mapfile/referencemanual-all-pages
Best regards,
Bart
Khaled Kamoun wrote:
> HI,
> I want to know if it's possible to put two attribute in labelitem, or
> concat two attribute.
> Thank you.
> Khaled KAMOUN
OSGIS, Open Source GIS
http://www.osgis.nl
