Retrieve swf(or other vector based format) by using wms
Eduard Witteveen
e.witteveen at HAWARIT.COM
Mon Apr 24 06:29:36 EDT 2006
First of all let me rephrase the bugs you gave me:
Eijnden, B. van den (Bart) wrote:
> It is not possible to advertize those formats in WMS Capabilities
> unfortunately.
> See also:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=455
Too much format's can cause certain clients to stop working with
mapserver, after which only the gd / gdal are exposed by mapserver.
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1072
The documentation was updated with the information that only the formats
gd and gdal are advertised (and by looking at the source code supported
during the getmap request)
[1] This still leave's me with the question, is there a way to retrieve
a single layer in *any* vector format, preferable a swf movie?
Currently i've been hacking around and I'm now retrieving multilayer
swf's from wms.
My goal is to enable output of single layer raster and vector based swf
files (the one's generated in the temp directory, and which are used in
the multilayer movie)
[2] Should i change the mapwms.c so it also supports swf(what should i
use as format-parameter, the outputformat name?)
or should i implement the wms by using mapscript/php(OWSRequest)
ps: I changed the topic, so it reads the correct subject ;)
Ing. Eduard Yeb Witteveen Software Engineer
Hawar Information Technology bv lid Dijkoraad Groep
De Wymerts 7 8701 WT Bolsward
Tel: +31 (0)515 570333 Fax: +31 (0)515 570335
http://www.hawarit.com/ nl_NL fy_NL en_US
