chart on the map
Tim Schaub
tim at COMMENSPACE.ORG
Mon Apr 24 13:05:17 EDT 2006
If you're looking for pie charts, I've put together some scripts that
may be of use.
> > I have spent a whole months to show chart on the mapserver,
> > I just want to ask : can i generate chart for each polygon on
> > mapserver?
> > Without using owtchart?
For an example, see
http://mapserver.commenspace.org/sustainable_seattle/demographic-map.php
Open the Transportation group, and refresh the map with the Commute Type
layer turned on.
If you're using (PHP) MapScript, and this seems like something you could
use. I'll pass it along.
Tim
> > Thanks for your all kindness
> > -Hadi-
> > West Java Indonesia
> Bill Binko <bill at binko.net>
