PNG24 output and GDAL dependency?
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Apr 26 08:57:40 EDT 2006
Hi list,
we are trying to create a minimal PHP/Mapscript rpm, but are running into
the issue that for 24 bits PNG output there is a dependency on GDAL. Why is
this and can it be avoided somehow?
Also, if we try to use 8 bit PNG (PC256 instead of RGB/RGBA), we get a
segfault in PHP/Mapscript if GDAL is not compiled in. If GDAL is compiled
in, all works fine.
Best regards,
Bart
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
