php help
Kevin Flanders
kevin at PEOPLEGIS.COM
Fri Apr 28 07:01:22 PDT 2006
I am retrieving a list of shapes from a line shapefile file using the
following code:
for($x=0;$x<count($oShapeList);$x++)
$oSelectedShape = $oRelationLayer->getshape(-1, $oShapeList[$x]);
array_push($oShapeObjectList,$oSelectedShape);
I want to merge this list of shapes into one shape (i.e. one line). I
thought I could do it using the following code but it returns a "Fatal
error: Object has an invalid _handle_ property":
$oLine = ms_newShapeObj(MS_SHAPE_LINE);
For($x=0; $x<count($oShapeObjectList);$x++)
$oLine->add($oShapeObjectList[$x]);
The goal here is to create one line, then use the GEOS - buffer(width) to
create a polygon object that I can save to a new shapefile.
Does anybody have any ideas? OR CODE!!!
Sincerely,
Bryon
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060428/a44e0003/attachment.htm>
More information about the MapServer-users
