Map File Problem?
M.L. Jackson
mljacks2 at HOTMAIL.COM
Tue Aug 1 13:09:36 EDT 2006
I tried the shp2img utility. I ended up with a perfect picture of a map of
the United States. No errors were generated at all shp2img. So I would
guess that the culprit is not the map file. Once I actually get my project
deployed correctly, I will also post some of the errors generated.
>From: Randy James <rjames57 at yahoo.com>
>To: "M.L. Jackson" <mljacks2 at hotmail.com>
>Subject: Re: [UMN_MAPSERVER-USERS] Map File Problem?
>Date: Fri, 28 Jul 2006 14:44:09 -0700 (PDT)
>Try posting the actual error message you get to the group, someone may have
>seen it before. Or better yet post the error log file from tomcat.
> I was thinking of the client browser not sending the correct url. I
>thought could be a iexplorer security issue as the problems sound like a
>trojan maybe on your lan generating errors. I just think errors are never
>random, but rather the cause is never fully understood so it appears
>random.
> randy
>"M.L. Jackson" <mljacks2 at hotmail.com> wrote:
> I think that the problem is not client side at all. The errors generated
>appear to come directly from the server. It could be the http server
>(Apache Tomcat) because I've also had deployment issues lately which I
>think
>I have resolved. I'm just really not sure at all about the errors. I guess
>I will have some trial and error debugging to do. I will also try the
>shp2img utility. Thanks. :-) Any other suggestions would be great as well.
> >From: Randy James
> >Reply-To: Randy James
> >To: MAPSERVER-USERS at LISTS.UMN.EDU
> >Date: Fri, 28 Jul 2006 10:16:43 -0700
> >The shp2img utility comes with mapserver. Could the problem be in your
>http
> >server rather than Mapserver? Or even a client side browser problem?
> > Randy
> >"M.L. Jackson" wrote:
> > Where is the shp2img utility? Does it come with mapserver or do you have
> >to
> >download it? Sorry for the newbie questions but thanks for your help.
> > >From: Jeff McKenna
> > >Reply-To: Jeff McKenna
> > >Date: Fri, 28 Jul 2006 11:46:39 -0400
> > >have u tried using the shp2img utility, to see if your mapfile is ok?
>I'd
> > >first make sure your mapfile is fine, then worry about your
>application.
> > >jeff
> > >M.L. Jackson wrote:
> > >>The thing is.......the errors occur at random. If the errors weren't
> > >>related to some central problem, then the same error should keep
> >occuring
> > >>until I fix it before any other errors are displayed. Instead each
>time
> > >>the server is restarted and the application is run a new error
> >supposedly
> > >>in the map file is displayed.
> > >>>From: Jeff McKenna
> > >>>Date: Fri, 28 Jul 2006 10:55:45 -0400
> > >>>I'm not sure about your random problem...but you might want to check
> >the
> > >>>errors section of the mapserver documentation page, and battle those
> > >>>errors one by one: http://mapserver.gis.umn.edu/docs/error
> > >>>jeff
> > >>>M.L. Jackson wrote:
> > >>>>Hi. I am running mapserver 4.6.0-beta1 with Java Mapscript on
>Tomcat.
> > >>>>While working on my project, I have encountered a weird series of
> > >>>>errors. Everytime I restart the server and try to run my
>application,
> >I
> > >>>>get an error indicating what appears to be any random line in the
>map
> > >>>>file. Most of the time the errors generated make absolutely no
>sense.
> > >>>>Among the errors generated are "projection not named" and "major
>axis
> > >>>>or radius = 0 or not given". The other errors are generally any line
> > >>>>number with a piece of the map file indicated. Thanks for your
> >replies.
> > >Jeff McKenna
> > >DM Solutions Group Inc.
> > >http://www.dmsolutions.ca
> >_________________________________________________________________
> >Dont just search. Find. Check out the new MSN Search!
> >http://search.msn.click-url.com/go/onm00200636ave/direct/01/
> >Yahoo! Music Unlimited - Access over 1 million songs.Try it free.
>Do you Yahoo!?
> Next-gen email? Have it all with the all-new Yahoo! Mail Beta.
On the road to retirement? Check out MSN Life Events for advice on how to
get there! http://lifeevents.msn.com/category.aspx?cid=Retirement
