how do I get rid of clicking the button and loading it my
html? {Scanned} {Scanned}
Albert Anderson
bart_doggers at YAHOO.COM
Thu Aug 3 12:25:36 EDT 2006
Hi Manfred,
Thanks! It works how I wanted it.
Albert
Manfred Meier <m.meier at spiekermann.de> wrote: Hi Albert,
I think this solution of David with the onload routine is really good.
But if you want to try the URL approach you could try:
http://your-host/cgi-bin/mapserv?program=mapserv&
map=/home/mapdata/richland.map&
mapext=625173.309834 5085113.091715 718065.960556 5160035.212592&
layers=aerial richland boundary cities roads sections rivers lakes
railroad parcels&
zoomsize=1
I did put together the informations from your html-code. You have to
change the hostname. Then put this URL in one line into the address
field of your browser. I hope, I made no mistakes and do not create
confusion.
Manfred
Albert Anderson schrieb:
> Hi Manfred,
> Yup your right with the button. Here is the code for the initializa button
Mapserver Richland County>
> [input]
> [input]
> value="mapserv">
> [input]
> value="/home/mapdata/richland.map">
> [input]
> value="625173.309834 5085113.091715 718065.960556
> 5160035.212592">
> [input]
> value="aerial richland boundary cities roads sections
> rivers lakes railroad parcels">
> [input]
> size="1" value="1">
> [input]
> [input]
> [input]
> [input]
> I would like the map to load up when I go to the url right away. So
> right when you type it in the address box and html page load that the
> map would too.
> Thanks for you time.
> Albert
> Manfred Meier wrote:
> Hi Albert,
> if I understand right, you have a page with an initialize button and
> when you click it you get a page with a map and this works fine, ok?
> So send us the html-code of your page with the button. Perhaps we can
> "create" an example url for you which you can put in the adress
> field of
> the browser.
> > You must pass the name of your map file.
> > For example:
> > http://your.server/cgi-bin/mapserv.exe?map=path/to/your/file.map
> > Where do I put that example at? Also I look at map context support
> It could be helpful, if you explain to us, how you want to load the map:
> - do want to load it from a menu or from a link?
> - or should your map be part of an html-page and and shall sit in a div
> or an iframe?
> Manfred
> > hi,
> > through cgi and I dont understand it. The site is
> > http://mapserver.gis.umn.edu/docs/reference/cgi/mapcontext
> > Could you help me.
> > Albert
> > Siki Zoltan wrote:
> > Hi Albert!
> > You can pass parameters through the url.
> > For example:
> > Zoltan
> > There aremany parameters you can set through the url, see the cgi
> > mapserver reference.
> > On Wed, 2 Aug 2006, Albert Anderson wrote:
> > > Hi,
> > > I am using intializing button as a submit button. The html
> > template is using the get method. I would like to know how to get
> > rid of the submit button. Just have the mapserver auto load into the
> > html without clicking the intializing and get the information from
> > the mapserver. Thanks
> > > Albert
> > > Manfred Meier wrote: I don't know your application and so don't
> > know which initialzing button
> > > you mean. But if there is a button then it is most likely a submit
> > > button of a form. Look at the source code of the html page in your
> > > browser and try to find out, to what url the action property in
> > the form
> > > tag points.
> > > If there are no other hidden or visible input tags, try to point
> > your
> > > browser to the url in the action property. If there are input
> > tags, try
> > > to append the neccessary values to the url.
> > > I don't know if that works in your case. But its a often used
> > method to
> > > circumvent the manual filling of forms.
> > > Manfred
> > > > Hi List,
> > > > My question is how do I get my page to load auto like without
> > using
> > > > initialzing button. I dont want to use the button. I just want
> > to page
> > > > just load. Is there a way around this? I'm using a linux
> > machine with
> > > > mapsever 4. Could someone help me?
> > > > Thanks,
> > > > Albert
> > > > Do you Yahoo!?
> > > > Next-gen email? Have it all with the all-new Yahoo! Mail Beta.
> > > Groups are talking. We´re listening. Check out the handy changes
> > to Yahoo! Groups.
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam? Yahoo! Mail has the best spam protection around
> > http://mail.yahoo.com
> Do you Yahoo!?
> Everyone is raving about the all-new Yahoo! Mail Beta.
Do you Yahoo!?
Get on board. You're invited to try the new Yahoo! Mail Beta.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060803/56d75f21/attachment.html
