Enabling ArcSDE crashes MapServer
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Tue Aug 8 09:20:09 EDT 2006
Kristian,
I'm not sure what MS4W version you are using, but 2.1 was released to
fix issues with the SDE and Oracle connections. Both were tested and
feedback from the community was that both work. Other than that I am
not sure of your problem.
jeff
Thy, Kristian wrote:
> I have installed the MS4W package on a Windows XP Pro box. We have
> tested and can succesfully display data from local shapefiles. But when
> I want to enable SDE connection support as per
> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#sde-9-1
> the new libmap.dll apparently makes mapserv.exe crash - I see a 500
> Server Error in the browser. Here's all I get in the Apache log:
> [Thu Aug 03 16:00:15 2006] [error] [client 127.0.0.1]
> Premature end of script headers: mapserv.exe,
> referer: http://localhost:8080/krak/
> The log file for the application itself is empty. Using the original
> libmap.dll, I have verified that the .map file is syntactically valid
> (but nothing is displayed, of course, since it's using SDE connected
> layers).
> Looking at mapserv.exe and libmap.dll in the Dependency Walker
> distributed with Visual Studio, I see absolutely no difference between
> using one or the other libmap.dll except that SDE91.dll is found and
> correctly linked with the SDE-enabled dll.
> Any ideas?
> Thanks in advance,
> Kristian
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
