WFS and uDIG IllegalArgumentException
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Tue Aug 8 17:40:18 EDT 2006
When trying to add a Web Feature Server to uDIG i am getting a
IllegalArgumentException.
when i post the same URL into the web browser the XML document that is
returned looks just fine, no warnings.
any ideas on what the problem could be, i havent seen anything posted
anywhere saying that uDIG has any problems with WFS. I can dispaly the
same features just fine in uDIG using a WMS
the URL
http://neuron/cgi-bin/mapserv?map=../html/mapserver/htdocs/wfs_service.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=hrsc_nd&
The error:
java.lang.IllegalArgumentException:
at org.eclipse.core.internal.runtime.Assert.isLegal(Assert.java:58)
at org.eclipse.core.internal.runtime.Assert.isLegal(Assert.java:42)
at org.eclipse.core.runtime.Status.setMessage(Status.java:174)
at org.eclipse.core.runtime.Status.<init>(Status.java:81)
at
net.refractions.udig.catalog.internal.wfs.WfsPlugin.log(WfsPlugin.java:110)
at
net.refractions.udig.catalog.internal.wfs.UDIGWFSDataStoreFactory.createNewDataStore(UDIGWFSDataStoreFactory.java:96)
at
org.geotools.data.wfs.WFSDataStoreFactory.createDataStore(WFSDataStoreFactory.java:108)
at
net.refractions.udig.catalog.internal.wfs.WFSServiceImpl.getDS(WFSServiceImpl.java:143)
at
net.refractions.udig.catalog.internal.wfs.WFSServiceImpl.members(WFSServiceImpl.java:95)
at
net.refractions.udig.catalog.internal.ui.ConnectionPage$1.run(ConnectionPage.java:133)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:830)
at
net.refractions.udig.catalog.internal.ui.ConnectionPage.getNextPage(ConnectionPage.java:147)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:747)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:556)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:143)
at
net.refractions.udig.internal.ui.UDIGApplication.run(UDIGApplication.java:28)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:163)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334)
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
The MapFile:
MAP
IMAGETYPE PNG
EXTENT -180 -90 180 90
#EXTENT -350878.81 -9890271.86 350878.81 9890271.86
SIZE 600 500
SHAPEPATH "../my_data/"
IMAGECOLOR 255 255 255
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
wfs_title "WFS test"
wfs_name "WFS test"
wfs_srs "EPSG:4326"
wfs_onlineresourc
"http://localhost/cgi-bin/mapserv?map=../html/mapserver/htdocs/wfs_service.map&"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "hrsc_nd"
#STATUS DEFAULT
STATUS off
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
DUMP TRUE
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost dbname=mars_db user=postgres"
DATA "the_geom FROM hrsc0001_footprints_sep05_nd"
METADATA
wfs_title "hrsc_nd"
wfs_srs "EPSG:4326"
wfs_onlineresourc
gml_include_items "all" ## Optional (serves all attributes for
layer)
END
CLASS
NAME "hrsc_nd"
STYLE
COLOR 200 255 0
OUTLINECOLOR 120 120 120
END
END
END # layer
END # of map file
