How can I know the name of the generated map
Manfred Meier
m.meier at SPIEKERMANN.DE
Wed Aug 9 01:14:02 EDT 2006
> generated gif file (map) for other purposes also, (like including it in
> a doc file or as attachment in an e-mail)
if you mean with doc-file that you create this file with a program
called word from a corporation called m... than you can perhaps do the
following:
In Word 2003 I can insert the picture with "Einfügen - Grafik - aus
Datei.." and then I give the whole URL (request to mapserver) as the
filename. Then I get back the image in the word document.
Depending on your special application perhaps it is possible for you to
generate the URL in WORD. So you have the most uptodate image and you
don't need to look for a file.
Manfred
Luis Treviño schrieb:
> Hi,
> I have an app that uses mapserver to display a generated map within
> other stuff (it´s a local application) with mode=map. I want to use the
> Can I tell to mapserver the name of the output gif file that I want?
> How can I know the name of the gif file just generated by mapserver?
> (without using the html <img> tag)
> any ideas?
> Thanks in advance
> Luis
