Mapscript C# - memory problem with GetShape
Tamas Szekeres
szekerest at GMAIL.COM
Wed Aug 9 12:34:02 EDT 2006
Would you describe your environment and the mapserver version in more detail?
Would you try getFeature instead of getshape. Note: tileindex and
shapeindex parameter should be switched.
Best Regards,
Tamas
2006/8/9, Sylvain Beorchia <sbeorchia at gi-lemans.com>:
> Hi,
> I use the method layer.getShape(shape, tileIndex, result.shapeindex) and
> I've got a sporadic error wich throws this AccessViolationException :
> "Attempted to read or write protected memory. This is often an indication
> that other memory is corrupt
> The StackTrace is :
> à mapscriptPINVOKE.layerObj_getShape(HandleRef jarg1,
> HandleRef jarg2, Int32 jarg3, Int32 jarg4)
> à layerObj.getShape(shapeObj shape, Int32 tileindex, Int32 shapeindex)
> à DI_DIFILE.DrawImg(Int32 Maprange, Int32 Mapsize, String Layer, String
> LayerIDValue, String Mapfile, String LayerID)
> Do you have an idea to fix this bug ?
