Image location inside its corner coordinates
Ed McNierney
ed at TOPOZONE.COM
Wed Aug 9 15:54:31 EDT 2006
Bruno -
I would suggest not mixing problems at this point - let's not worry
about ows_ metadata settings until you get the simple image display to
work properly. Please leave out the METADATA statements until the image
displays properly; then you'll be able to add the METADATA back in
without being confused about what settings are helping and what settings
are causing trouble.
Yes, I suggested UNITS DD because your output and input image units are
decimal degrees.
You should have EXTENT and UNITS statements at the top level in your map
file, and a PROJECTION block there, too (with the same settings as
below, as you seem to want to display the image in its native
unprojected coordinates). Is that the case? Can you post the whole map
file? Are there other LAYER statements in the file?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
From: Bruno Patini Furtado [mailto:bpfurtado at gmail.com]
Sent: Wednesday, August 09, 2006 1:47 PM
To: Ed McNierney
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] Image location inside its corner
coordinates
Hi Ed,
On 8/9/06, Ed McNierney <ed at topozone.com> wrote:
Bruno -
Could you post the EXTENT statement you're using? Two things to
check - UNITS DD should be there (should not affect this problem,
however) and your EXTENT needs to be in the order MINX MINY MAXX MAXY,
so it should be:
EXTENT -48.0004159 -25.0004164 -46.5004159 -24.0004163
My extent is indeed like you said it should be:
It was because of the line below that you state that the units should be
Decimal Degrees?
UNIT["degree",0.0174532925199433],
Your image is 1.5 degrees wide (X dimension) and 1 degree tall
(Y dimension) so your output image size should also be that shape (600
pixels wide by 400 pixels high, for example) or you will see the map
shrunk to fit the shape of the image.
Your example shows the right proportion as gdalinfo tells the image is
[1800, 1200] but I would like to set the layer metadata ows_extent with
the actual image coordinates, not size, in order to show the image a bit
better in the MapServer demo. Below goes my mapinfo layer element as I'm
trying to configure it.
LAYER
NAME "my DEM Image"
STATUS OFF
TYPE RASTER
DUMP TRUE
DATA "SG-23-V-A.tif"
PROJECTION
"init=epsg:4326"
END
METADATA
wcs_label "Some label"
ows_extent "- 48.000416 -24.000416 -48.001816 -24.001816"
wcs_resolution "0.00083 -0.00083"
ows_srs "EPSG:4326"
wcs_formats "GEOTIFFINT16"
wcs_nativeformat "geotiff"
END
END
- Ed
Ed McNierney
ed at topozone.com
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Bruno Patini Furtado
Sent: Wednesday, August 09, 2006 10:59 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Image location inside its corner
coordinates
I have a DEM image of which below I've copied the gdalinfo
output.
Driver: GTiff/GeoTIFF
Size is 1800, 1200
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
AUTHORITY["EPSG","4326"]]
Origin = (-48.000416,-24.000416)
Pixel Size = (0.00083333,-0.00083333 )
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=IMAGINE TIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: etif.c $ $Revision: 1.10.1.9 $ $Date: 2003/11/13
19:25:49EST $
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Corner Coordinates:
Upper Left ( -48.0004159, -24.0004163) ( 48d 0'1.50"W, 24d
0'1.50"S)
Lower Left ( -48.0004159, -25.0004164 ) ( 48d 0'1.50"W, 25d
0'1.50"S)
Upper Right ( -46.5004159, -24.0004163) ( 46d30'1.50"W, 24d
0'1.50"S)
Lower Right ( -46.5004159, -25.0004164) ( 46d30'1.50"W, 25d
0'1.50"S)
Center ( -47.2504159, -24.5004163) ( 47d15'1.50"W,
24d30'1.50"S)
Band 1 Block=1800x2 Type=UInt16, ColorInterp=Gray
Overviews: 450x300, 225x150, 113x75, 57x38
I could take from it the EXTENT to use in my Mapfile using the
Lower Left and Upper Right coordinates. But the problem is that the
image is to small inside this coordinates and I can't find the image
location inside then by this output. Is there some other utility to get
this coordinates?
"Minds are like parachutes, they work best when open."
Software Developer
webpage: http://bpfurtado.net
software development blog: http://bpfurtado.livejournal.com
Software Developer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060809/f9b1fc49/attachment.html
