Image location inside its corner coordinates
Norman Barker
nbarker at ITTVIS.COM
Thu Aug 10 10:55:40 EDT 2006
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Bruno Patini Furtado
Sent: Thursday, August 10, 2006 3:51 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Image location inside its corner
coordinates
Hi Ed,
On 8/9/06, Ed McNierney <ed at topozone.com> wrote:
Bruno -
I would suggest not mixing problems at this point - let's not worry
about ows_ metadata settings until you get the simple image display to
work properly. Please leave out the METADATA statements until the image
displays properly; then you'll be able to add the METADATA back in
without being confused about what settings are helping and what settings
are causing trouble.
My original motivation to adjust the ows_extent was to treat this
problem but following your advice e changing the units to decimal
degrees my zoom problem was solved, thanks a lot!
Yes, I suggested UNITS DD because your output and input image
units are decimal degrees.
You should have EXTENT and UNITS statements at the top level in
your map file,
and a PROJECTION block there, too (with the same settings as
below, as you seem to want to display the image in its native
unprojected coordinates). Is that the case? Can you post the whole map
file?
I did not had a PROJECTION element other than the one in my LAYER
element. Now based on the lines bellow outputted by gdalinfo:
GEOGCS["WGS 84",
DATUM["WGS_1984",
I've created the following PROJECTION element:
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
But I'm not sure if that's correct.
Here goes my hole mapfile (based on the mapserver demo Itasca mapfile):
MAP
NAME ITASCA
STATUS ON
SIZE 600 600
EXTENT -48.0004159 -25.0004164 -46.5004159 -24.0004163
UNITS DD
SHAPEPATH "data"
IMAGECOLOR 255 255 255
TEMPLATEPATTERN "itasca"
IMAGETYPE PNG
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
# Start of web interface definition (including WMS enabling
metadata)
WEB
HEADER templates/header.html
TEMPLATE "set in index.html"
FOOTER templates/footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in index.html"
IMAGEURL "set in index.html"
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is a UMN MapServer application for Itasca
County located in north central Minnesota."
WMS_ACCESSCONSTRAINTS "none"
# change this value to match your setup
WMS_ONLINERESOURCE "http://10.10.5.171/cgi-bin/mapserv.exe "
WMS_SRS "EPSG:26915"
END
END
# Start of reference map
REFERENCE
IMAGE graphics/reference.png
EXTENT 324152.222 7384541.141 336175.222 7392179.141
SIZE 120 120
STATUS ON
MINBOXSIZE 5
MAXBOXSIZE 100
COLOR 255 0 0
OUTLINECOLOR 0 0 0
MARKERSIZE 8
MARKER 'star'
END
OUTPUTFORMAT
NAME GEOTIFFINT16
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE "INT16"
EXTENSION "tif"
END
LAYER
NAME "MyLayer"
STATUS OFF
TYPE RASTER
DUMP TRUE
DATA "SG-23-V-A.tif"
PROJECTION
"init=epsg:4326"
END
END
END
Are there other LAYER statements in the file?
No, I'm just trying with one at the moment for the sake of simplicity.
In fact I want to display a DEM (Digital Elevation Model) image through
WCS (Web Coverage Service) in order to open it in the OpenJUMP
application ( The use of OpenJUMP is a mandatory requirement). For that
I want first to test the availability of WCS of this DEM in the
MapServer Demo application.
<Norman>
To display a DEM through the MapServer WCS there are instructions here
that have been gathered by lots of us doing this work;
http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
if you have any problems please post back to the list. The excellent
ICEDS service (Jeremy Morley - UCL) serves DEM using MapServer.
</Norman
That's my current strategy to achieve this objective, any suggestions
would be most appreciated :) ( but I know, this can be a subject for a
hole new post to this list).
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
From: Bruno Patini Furtado [mailto:bpfurtado at gmail.com]
Sent: Wednesday, August 09, 2006 1:47 PM
To: Ed McNierney
Cc: MAPSERVER-USERS at lists.umn.edu
corner coordinates
Hi Ed,
Bruno -
Could you post the EXTENT statement you're using? Two things to
check - UNITS DD should be there (should not affect this problem,
however) and your EXTENT needs to be in the order MINX MINY MAXX MAXY,
so it should be:
My extent is indeed like you said it should be:
It was because of the line below that you state that the units
should be Decimal Degrees?
UNIT["degree",0.0174532925199433],
Your image is 1.5 degrees wide (X dimension) and 1 degree tall
(Y dimension) so your output image size should also be that shape (600
pixels wide by 400 pixels high, for example) or you will see the map
shrunk to fit the shape of the image.
Your example shows the right proportion as gdalinfo tells the
image is [1800, 1200] but I would like to set the layer metadata
ows_extent with the actual image coordinates, not size, in order to show
the image a bit better in the MapServer demo. Below goes my mapinfo
layer element as I'm trying to configure it.
LAYER
NAME "my DEM Image"
STATUS OFF
TYPE RASTER
DUMP TRUE
PROJECTION
"init=epsg:4326"
END
METADATA
wcs_label "Some label"
ows_extent "- 48.000416 -24.000416 -48.001816
-24.001816"
wcs_resolution "0.00083 -0.00083"
ows_srs "EPSG:4326"
wcs_formats "GEOTIFFINT16"
wcs_nativeformat "geotiff"
END
END
- Ed
Ed McNierney
ed at topozone.com
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU ] On Behalf Of Bruno Patini
Furtado
Sent: Wednesday, August 09, 2006 10:59 AM
Subject: [UMN_MAPSERVER-USERS] Image location inside its
corner coordinates
I have a DEM image of which below I've copied the
gdalinfo output.
Driver: GTiff/GeoTIFF
Size is 1800, 1200
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
AUTHORITY["EPSG","4326"]]
Origin = (-48.000416,-24.000416)
Pixel Size = (0.00083333,-0.00083333 )
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=IMAGINE TIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: etif.c $ $Revision: 1.10.1.9 $ $Date:
2003/11/13 19:25:49EST $
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Corner Coordinates:
Upper Left ( -48.0004159, -24.0004163) ( 48d 0'1.50"W,
24d 0'1.50"S)
Lower Left ( -48.0004159, -25.0004164 ) ( 48d 0'1.50"W,
25d 0'1.50"S)
Upper Right ( -46.5004159, -24.0004163) ( 46d30'1.50"W,
24d 0'1.50"S)
Lower Right ( -46.5004159, -25.0004164) ( 46d30'1.50"W,
25d 0'1.50"S)
Center ( -47.2504159, -24.5004163) ( 47d15'1.50"W,
24d30'1.50"S)
Band 1 Block=1800x2 Type=UInt16, ColorInterp=Gray
Overviews: 450x300, 225x150, 113x75, 57x38
I could take from it the EXTENT to use in my Mapfile
using the Lower Left and Upper Right coordinates. But the problem is
that the image is to small inside this coordinates and I can't find the
image location inside then by this output. Is there some other utility
to get this coordinates?
"Minds are like parachutes, they work best when open."
Software Developer
webpage: http://bpfurtado.net
software development blog:
http://bpfurtado.livejournal.com
Software Developer
software development blog: http://bpfurtado.livejournal.com
Software Developer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060810/e43ba697/attachment.html
