OVF file syntax
Tyler Mitchell
tylermitchell at SHAW.CA
Fri Aug 11 23:58:35 EDT 2006
On 11-Aug-06, at 3:57 PM, P Kishor wrote:
> I have a CSV file called 'foo.txt' inside a directory called 'bar'.
> The first row contains column headers. I am trying to construct a
> meaningful OVF file like so, but failing.
> <OGRVRTDataSource>
> <OGRVRTLayer name="foo">
> <SrcDataSource>CSV:"C:\\path\\to\\bar"</SrcDataSource>
> <SrcLayer>foo.txt</SrcLayer>
> <GeometryField encoding="PointFromColumns" x="LONGITUDE"
> y="LATITUDE"/>
> <GeometryType>wkbPoint</GeometryType>
> </OGRVRTLayer>
> </OGRVRTDataSource>
Hi Puneet,
From my experience you have to treat the text file as the datasource
and the (only) layer will have the same prefix. So don't point to
the folder, instead point to the file itself as the datasource.
Also, it seems ogr likes to have the CSV file with a .csv extension.
Even adding that CSV: prefix doesn't do the trick for me - so rename
your text file.
So here is what works for me:
$ cat foo.ovf
<OGRVRTDataSource>
<SrcDataSource>foo.csv</SrcDataSource>
<SrcLayer>foo</SrcLayer>
<GeometryField encoding="PointFromColumns" x="lon" y="lat"/>
</OGRVRTLayer>
</OGRVRTDataSource>
$ cat foo.csv
"lat","lon"
54,124
55,122
Hope it helps,
Tyler
