Real time Data
Manfred Meier
m.meier at SPIEKERMANN.DE
Sat Aug 12 05:16:00 EDT 2006
Hello,
I do not have a running example. But I have such data and could use such
a solution too.
A solution could be: With a javascript timer or a http-refresh in your
html page trigger a reload every 10 or less minutes. If your script on
the server side sees that the data has not been changed, it could send a
http-header 204 (no content). I have tried this once and it seems that
the browser does not make a refresh then (= no flickering screen). If
the data has changed, the server sends a new image. If you put your map
into an iframe then it is simpler to realize I think.
On the mapserver list had been such questions many times for example for
showing the gps signals from vehicles. You could ook at the map archive.
Manfred
K S schrieb:
> Hi everyone,
> I try to have real time data on mapserver. More specifically I would
> like to have data which change every 10 minutes and mapserver should
> show a new map based on the changed data. I have no idea how could this
> be possible.Any help would be very useful.
> Thanks in advance.
> Χρησιμοποιείτε Yahoo!
> Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την
> καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
> http://login.yahoo.com/config/mail?.intl=gr
