Easy way to get standalone mapserver already compiled
M.L. Jackson
mljacks2 at HOTMAIL.COM
Mon Aug 14 16:07:54 EDT 2006
I downloaded MS4W before but I noticed that there was a lot of unneeded
programs included as well as an Apache server which was of no use to me. I
never explored the cgi-bin directory. After reading your reply and looking
in the cgi-bin directory, I found exactly what I needed.
I basically copied all of mapserver's dependent libraries (and I'm sure some
other unneeded dll files) from the cgi-bin directory into a system folder.
I made sure that Tomcat added this system folder to its library path so that
mapscript/mapserver could find the .dll files when needed. I then copied
the mapscript.jar file found in cgi-bin/mapscript/java into my project's
WEB-INF/lib directory. Because Tomcat is sometimes flimsy, it would be a
good idea to manually copy the mapscript.jar file to your project's
WEB-INF/lib directory within Tomcat and not depend upon deployment
necessarily doing the job correctly.
Well, not a very detailed write-up but due to time constraints it is the
best that I can do. Maybe someone can take this write-up and make it more
detailed and formal. If no one can, I can probably write it up at a later
date. By the way, I am using MyEclipse for my mapserver project
development.
Thanks, Jeff.
>From: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>Reply-To: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Easy way to get standalone mapserver
>already compiled
>Date: Fri, 11 Aug 2006 18:57:07 -0400
>Um, isn't that what MS4W is?
>I think the only thing it is missing for you would be a java servlet right?
> Tomcat or something? You can definitely start with MS4W and add
>configure that for your servlet...but I am no java guy so I am no precise
>help.
>If you do decide to use MS4W, maybe you could document your work and
>possibly contribute a java section to the readme for MS4W? (meaning what
>it took you to use the files in \ms4w\Apache\cgi-bin\mapscript\java\).
>jeff
>M.L. Jackson wrote:
>>What I am essentially looking for is a fully compiled distribution of
>>mapserver for Windows. Instead of having to compile the entire mapserver
>>source code, I would like to download a fully compiled package with
>>support for all the programming languages (in particular Java mapscript)
>>and all the essential supporting libraries for full functionality plus wms
>>support without the hassle. Am I asking for too much? :-)
>>>From: "Rahkonen Jukka" <Jukka.Rahkonen at mmmtike.fi>
>>>To: "M.L. Jackson" <mljacks2 at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
>>>Subject: RE: [UMN_MAPSERVER-USERS] Easy way to get standalone mapserver
>>>already compiled
>>>Date: Fri, 11 Aug 2006 23:31:54 +0300
>>>Hi,
>>>How about Mapserver included in the FW Tools set, could it be something
>>>close to what you are searching for?
>>>-Jukka Rahkonen-
>>>-----Original Message-----
>>>From: UMN MapServer Users List on behalf of M.L. Jackson
>>>Sent: Fri 11.8.2006 22:58
>>>Subject: [UMN_MAPSERVER-USERS] Easy way to get standalone mapserver
>>>already compiled
>>>Is there an easy way to get mapserver and all its supporting libraries in
>>>an
>>>already compiled package with nothing else included? I am having a
>>>headache
>>>trying to compile the source code. Thanks.
>Jeff McKenna
>DM Solutions Group Inc.
>http://www.dmsolutions.ca
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today - it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
