PHP Map Obj Serialize
    P Kishor
    punkish at EIDESIS.ORG
    Tue Aug 15 05:58:40 PDT 2006
I know very little about the current state of PHP/MapScript, but I
have implemented what you propose below. It does not require mucking
around with mapObj at all.
Think of how any given map is formed -- it requires a query sent
either via GET or POST. All you have to do is store that query (it is
already serialized by http for you), associate it with a memorable
name ('My House', 'My Cat's Sleeping Place') and the resulting png
image cached somewhere safe where it doesn't get cleaned up by your
normal hard disk maid service, and store the three as you wish -- in
an associative array, in a file, in 3 fields of a database table,
whatever you want.
Next time your user clicks on her 'My House', you check if the
associate png is present and use it, if not, use the associated query
to regenerate it, and restore it.
On 8/15/06, Stuart Eve <stuarteve at lparchaeology.com> wrote:
> Dear all,
> We are attempting to think of a way to provide a 'permalink' to a
> particular map object. In addition we would like to do a check to see if
> the server has already created that map (with its specific
> configuration) before and so just load up the cached png instead of
> recreating the png each time.
> I realise we can save out the mapfile to a .txt file and then read it in
> - and compare it to all of the other mapfiles we have saved, but it
> seems like it may be a little processor heavy. We were hoping to save
> something out to a field in the MySQL table. We were thinking along the
> lines of a serialized array which could then be compared with the other
> cached arrays in the MySQL table and see if theres a match.
> Our main problem, though, is that we can't unserialize a map object (as
> it loses all of its methods). Is there a way to unserialize the map
> object and make it function properly again as a map object or
> alternatively output the mapfile to a field in the database and then
> recreate the map object from that? Does the mapObj constructor only work
> from files?
> We are using Mapserver 4.8 and PHPMapscript.
> Thanks in advance
> Stuart
> Stuart Eve
> L - P : Archaeology
Puneet Kishor http://punkish.eidesis.org/
Nelson Inst. for Env. Studies, UW-Madison http://www.ies.wisc.edu/
Open Source Geospatial Foundation https://edu.osgeo.org/
More information about the MapServer-users
