WFS and PROPERTYNAME
Eijnden, Bart van den (AGI)
b.vdeijnden at AGI.RWS.MINVENW.NL
Thu Aug 17 06:41:50 EDT 2006
This is currently not supported, see also:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=675
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Daniel Goetz
Verzonden: donderdag 17 augustus 2006 12:40
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] WFS and PROPERTYNAME
I am using a local mapserver installation (ms4w 2.1) and I built up a WFS-server with mapserver. Now I want to do a GetFeature request using a "propertyname=" parameter as it is decribed in the OGC WFS Specification 1.0.0 (https://portal.opengeospatial.org/files/?artifact_id=7176) (page 67, Example 2). The there given example looks as follows:
http://www.someserver.com/wfs.cgi&
SERVICE=WFS&
VERSION=1.0.0&
REQUEST=GetFeature&
PROPERTYNAME=INWATERA_1M/WKB_GEOM,INWATERA_1M/TILE_ID&
TYPENAME=INWATERA_1M
The URL I use is this ("BL" is the name of the layer and the wfs_title in the LAYER-METADATA-object and "NAME" is the column-name in the attribute-table):
http://localhost/cgi-bin/mapserv.exe?map=[path to mapfile]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&PROPERTYNAME=BL/NAME&TYPENAME=BL
Unfortunately the XML/GML document I get back includes all property-elements that are contained in the attribute-table of my shapefile (.dbf) and not only information about the property-element I specified in the request (PROPERTYNAME=BL/ANME). Why?
I think the problem lies in the "gml_include_items" parameter I specified in the LAYERs METADATA object. The value for this parameter is set to "all". The mapserver-wfs-server-howto (http://mapserver.gis.umn.edu/docs/howto/wfs_server) tells this should be a optional parameter. But when I leave it out of my .map-file no property-elements are shown in the XML/GML (except <gml:coordinates>) doesn't matter what value I define for the PROPERTYNAME parameter in the GetFeature-request.
Is mapserver not able to handle such an GetFeature request, in which a PROPERTYNAME parameter is set?
Thank you for your help and your ideas.
regards
Daniel
P.S. Here is the .map-file I use:
MAP
EXTENT 3280310.846135 5237417.972512 3921417.690365 6103136.474612
PROJECTION
"init=epsg:31467"
END
SIZE 344 442
IMAGETYPE PNG
IMAGECOLOR 255 255 255
UNITS METERS
STATUS ON
SHAPEPATH "/ms4w/Apache/htdocs/wfs/daten"
#----------------WEB-Objekt----------------------------------
WEB
IMAGEPATH "/ms4w/apache/htdocs/tmp/"
IMAGEURL "/tmp/"
TEMPLATE "template_daniel3.html"
METADATA
"WFS_title" "WFS_SHAPE"
"WFS_srs" "EPSG:31467"
"WFS_onlineressource" "http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/WFS/WFS_SHAPE.map"
END #METADATA
END #WEB
LAYER
NAME "BL"
DATA "bundeslaender.shp"
TYPE POLYGON
STATUS ON
PROJECTION
"init=epsg:31467"
END #Projection
TEMPLATE template_select.html
DUMP TRUE
METADATA
"WFS_TITLE" "BL"
"gml_include_items" "ID,FLAECHE,UMFANG,NAME"
"wfs_featureid" "ID"
END #Metadata
CLASS
NAME "class1"
STYLE
COLOR 127 191 255
END #Style
STYLE
OUTLINECOLOR 255 0 0
WIDTH 1
ANTIALIAS TRUE
END #Style
END #Class
END
END
"Feel free" – 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
