layer configuration for WMS
Zenon Panoussis
oracle at PROVOCATION.NET
Sat Aug 19 21:55:54 EDT 2006
xslove wrote:
> I try configure mapserver map file. I define layer as wms request, I thing it
> is good, but when I post request, layer is not drawn. My mapfile named
> wmsjpl.map is
> outputformat
> name png
> driver 'GD/png'
> mimetype 'image/png'
> extension 'png'
> end
I am not sure about this, but I think you might need an
IMAGETYPE PNG
to go with it, or perhaps could do with only that and no OUTPUTFORMAT.
> web
> imagepath 'tmp'
> imageurl 'tmp'
The imagepath is relevant to your file system, the imageurl to
the webserver's document root. Try (adjusting to your system)
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/tmp/"
and see if it helps.
> layer
> name 'da'
> type raster
> offsite 0 0 0
> status on
Try STATUS DEFAULT to force-display it, then switch it back to ON
when you know it works and have controls in place to turn it on.
Z
