layer configuration for WMS
Zenon Panoussis
oracle at PROVOCATION.NET
Sun Aug 20 20:33:45 EDT 2006
I wrote:
> With single quotes it doesn't work, with double quotes it does.
It seems I'm wrong, there's something fishy going on. Playing around
with it, suddenly I couldn't zoom closer than some fixed scale, it
kept returning a blank map. Then a moment later I could zoom in anyway.
So I put back the single quotes and it works with them too, but not
every time. My guess is that the JPL server times out and/or drops
requests, I can't see any other explanation for this. In any case,
here's the entire map file I used:
MAP
NAME TEST
STATUS ON
SIZE 900 500
EXTENT -180 -90 180 90
UNITS DD
IMAGETYPE PNG24
OUTPUTFORMAT
NAME png24
DRIVER "GDAL/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
SHAPEPATH "shp/"
FONTSET "fontset.txt"
SCALEBAR
STATUS EMBED
UNITS KILOMETERS
INTERVALS 3
TRANSPARENT TRUE
OUTLINECOLOR 0 0 0
END #End of SCALEBAR
WEB
TEMPLATE global.html
MAXSCALE 125992916
IMAGEPATH "/vol/www/www/tmp/"
IMAGEURL "/tmp/"
LOG "/vol/www/logs/mapserver.log"
END #End of WEB
layer
name 'da'
type raster
offsite 0 0 0
status DEFAULT
connectiontype wms
connection "http://wms.jpl.nasa.gov/wms.cgi?"
metadata
"wms_title" "global"
"wms_srs" "EPSG:4326"
"wms_name" "global_mosaic"
"wms_style" "visual"
"wms_server_version" "1.1.1"
"wms_format" "image/jpeg"
"wms_force_separate_request" "1"
end
projection
'init=EPSG:4326'
end
end
END #End of MAP
Z
