layer configuration for WMS
xslove
xslove at CENTRUM.CZ
Mon Aug 21 07:38:49 EDT 2006
Well, I try request with your mapfile (a bit modification with paths), but
still nothing. Also I correct all quotes to double. Also I modify layer
connection for request on my local server. This servlet is never called by
mapserver - mapserver simple ignore this wms layer! It run under Windows XP
and version is 4.8.4. Can this be a problem?
here is your (my) modified mapfile
MAP
NAME TEST
STATUS ON
SIZE 900 500
EXTENT -180 -90 180 90
UNITS DD
IMAGETYPE PNG24
OUTPUTFORMAT
NAME png24
DRIVER "GDAL/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
SHAPEPATH "/shp/"
FONTSET "/tmp/font/fontset"
projection
"init=EPSG:4326"
end
SCALEBAR
STATUS EMBED
UNITS KILOMETERS
INTERVALS 3
TRANSPARENT TRUE
OUTLINECOLOR 0 0 0
END #End of SCALEBAR
WEB
TEMPLATE global.html
MAXSCALE 125992916
IMAGEPATH "/tmp/"
IMAGEURL "/tmp/"
LOG "/tmp/logs/mapserver.log"
END #End of WEB
layer
name "da"
type raster
offsite 0 0 0
status DEFAULT
connectiontype wms
connection "http://wms.jpl.nasa.gov/wms.cgi?"
#connection "http://localhost:8080/ghory/wms?req=t" - my test servlet
listener - it is never called!
metadata
"wms_title" "global"
"wms_srs" "EPSG:4326"
"wms_name" "global_mosaic"
"wms_style" "visual"
"wms_server_version" "1.1.1"
"wms_format" "image/jpeg"
"wms_force_separate_request" "1"
end
projection
"init=EPSG:4326"
end
end
END #End of MAP
and one of my requests
http://10.133.28.149:8081/cgi/mapserv.exe?map=test.map&service=wms&version=1.1.1&request=GetMap&width=488&height=380&bbox=-5,-5,5,6&layers=da
View this message in context: http://www.nabble.com/layer-configuration-for-WMS-tf2133082.html#a5905214
Sent from the Mapserver - User forum at Nabble.com.
