How to calculate x and y pixel width for world file?
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Aug 21 11:19:43 EDT 2006
Something like this would do the trick:
x_pixel_width = abs((maxx - minx)) / width
y_pixel_width = abs((maxy - miny)) / height
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Paul Maine(ATS)
> Sent: 21 August, 2006 11:11 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] How to calculate x and y pixel
> I am using ESRI SOAP webservices to obtain a map for use with
> Mapserver. I know that in order to use the map that is
> formatted as a gif - that I need to create world file.
> Since I know the extent of the map image - do I need to use a
> world file?
> See the following for info on how to create a world file:
> http://mapserver.gis.umn.edu/docs/howto/raster_data/#georefere
> nce-with-world
> How can I obtain the x and y pixel widths from the following
> information that is returned from the web service? I am
> creating the map as an 800 x 800 pixel gif file.
> Here is the relevant information that is returned by the webservice:
> <n2:MapImageInfo xsi:type='n2:MapImageInfo'> ...
> <mapArea xsi:type='n2:MapArea'>
> <extent xsi:type='n3:Envelope'>
> ... <projection xsi:type='xsd:string'>4326</projection>
> <maxX xsi:type='xsd:double'>-117.10667</maxX>
> <maxY xsi:type='xsd:double'>34.13056</maxY>
> <minX xsi:type='xsd:double'>-117.25667</minX>
> <minY xsi:type='xsd:double'>33.98056</minY>
> Thank You
