WMS/WFS and no geometry in GML output
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Aug 22 00:57:32 EDT 2006
Bart: I committed a simple fix for this bug tonite. WMS will recognize
WMS_GEOMETRIES and WFS will recognize WFS_GEOMETRIES, or you could use
GML_GEOMETRIES and hit both services. Can you try it out and let me
know?
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-259-5473
>>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 08/21/06 2:23 PM >>>
This should not be too hard to set up this way. We'd just need to pass
the allowable metadata prefixes into
the geometry property parser. With WMS we'd want to allow GML_, OWS_
and WMS_ and for WFS something
similar but allowing WFS_. If a bug is filed this could be fixed by
beta 2. I should've set it up that way in the
first place.
Steve
>>> "Eijnden, Bart van den (AGI)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
8/21/2006 2:37:08 AM >>>
Hi list,
referring to Steve Lime's e-mail 23-05-2006 with the subject "WFS
without geometry", I wondered if it is possible to have WMS
GetFeatureInfo not output the geometries, but have WFS output them? This
would be a common use-case in my opinion.
Now the tag is GML_GEOMETRIES "none", but this would require
WMS_GEOMETRIES and WFS_GEOMETRIES, so that WMS and WFS can be seen
separately. Any thoughts?
Best regards,
Bart van den Eijnden
drs. A.J. van den Eijnden
adviseur
Productteam Applicaties Geo-Informatie
Rijkswaterstaat Adviesdienst Geo-informatie en ICT
Postbus 5023, 2600 GA Delft
Derde Werelddreef 1, 2622 HA Delft
Telefoon: (015) 275 75 75
E-mail b.vdeijnden at agi.rws.minvenw.nl
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
