using OGR to connect MySQL
Jacolin Yves
yjacolin at FREE.FR
Tue Aug 22 03:57:50 EDT 2006
Have you try to do make clean before to run again make ? You have to clean
each time you run again ./configure.
Try to uninstall your rpm package.
Regards,
Y.
Le Mardi 22 Août 2006 09:05, vous avez écrit :
> Dear Jacolin,
> Thank you for your help.
> I2m sorry but I coulnd't reinstall gdal with ogr functionallity.
> results of my configure as follows.
> GDAL is now configured for i686-pc-linux-gnu
> Installation directory: /usr/local
> C compiler: gcc -O2
> C++ compiler: g++ -O2
> LIBTOOL support: yes
> LIBZ support: external
> GRASS support: libgrass
> CFITSIO support: no
> PCRaster support: internal
> NETCDF support: yes
> LIBPNG support: external
> LIBTIFF support: external
> LIBGEOTIFF support: internal
> LIBJPEG support: external
> LIBGIF support: internal
> OGDI support: yes
> HDF4 support: no
> HDF5 support: no
> KAKADU support: no
> JASPER support: no
> ECW support: no
> MrSID support: no
> POSTGRESQL support: no
> MySQL support: yes
> XERCES support: yes
> ODBC support: no
> OCI support: no
> SDE support: no
> DODS support: no
> SQLite support: no
> DWGdirect support no
> PANORAMA GIS support: no
> GEOS support: no
> Statically link PROJ.4: no
> Traditional Python: no
> NG SWIG Bindings:
> enable OGR building: yes
> When I try to make it following error messages returns
> make[4]: *** [../../o/iom_attr.o] Error 1
> make[4]: Leaving directory `/usr/local/gdal-1.3.2/ogr/ogrsf_frmts/ili/iom'
> make[3]: *** [iom-target] Error 2
> make[3]: Leaving directory `/usr/local/gdal-1.3.2/ogr/ogrsf_frmts/ili'
> make[2]: *** [ili-target] Error 2
> make[2]: Leaving directory `/usr/local/gdal-1.3.2/ogr/ogrsf_frmts'
> make[1]: *** [sublibs] Error 2
> make[1]: Leaving directory `/usr/local/gdal-1.3.2/ogr'
> make: *** [ogr-target] Error 2
> so I couldn't rebuild gdal with mysql and ogr
> Before this I was installed rpm package of gdal-1.1.9-2mdk.i586.rpm.
> Do you have any idea what is the solution of my problem. And Really I would
> like to connect MySQL and read data from database to draw epicenter map of
> Erathquake in Turkey.
> Please if you have any idea I'm wellcome...
> Murat
> On Mon, 21 Aug 2006 16:32:49 +0200, Jacolin Yves wrote
> > Le Lundi 21 Août 2006 16:19, Jacolin Yves a écrit :
> > > > By the consider command mapserv -v I have already installed mapserver
> > > > with ogr functionality. Is it true?
> > Yes I think you don't need to build again mapserver :-)
> > Y.
> > Yves Jacolin
> > http://yjacolin.gloobe.org
> > Stagiaire Conservatoire Régional des Espaces Naturels de la région Centre
> > http://cahiersnaturalistes.free.fr/cpnrc/
> > - Qu'est-ce que cela peut faire que je lutte pour la mauvaise cause
> > puisque je suis de bonne foi?
> > - Et qu'est-ce que ça peut faire que je sois de mauvaise foi
> > puisque c'est pour la bonne cause. (Jacques Prévert)
> > This message has been scanned for viruses and
> > dangerous content by MailScanner, and is
> > believed to be clean.
> Open WebMail Project (http://openwebmail.org)
Yves Jacolin
