performance with different data formats
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed Aug 23 02:00:07 EDT 2006
Mark,
some things that come to my mind:
1. Mapserver's query mechanism is quite inefficient against database
sources (two pass, and pass by id to get the actual record, so for every
feature in your resultset a SQL statement is executed against the DB).
So I am not surprised about your query performance, I have had the same
experiences. What USING UNIQUE clause are you using in your MAP file,
and can you check that this pass by ID is indexed in the database?
2. You could try Mapserver as a Fast-CGI since connection overhead could
be an issue
3. You could also get Mapserver to output the XML (i.e. GML) of a
FeatureCollection if you would use the Mapserver WFS interface. Then
using an XSLT you could create your HTML table. Maybe this is faster,
but it still suffers from 1. ofcourse.
Hope this helps.
Best regards,
Bart
Mark Adams wrote:
> Hi All,
> I’m looking for ideas and explanations regarding performance when
> publishing maps from ArcSDE and Oracle Spatial, and also with
> displaying attribute data from these data source. We have been working
> for a while now with from these formats through MapServer and PHP
> mapscript, and have found the performance has been disappointing.
> Specifically, we are trying to use Oracle Spatial (9i) as well as
> ArcSDE against both Oracle and SQL Server (we gave up entirely on MS
> Access personal geodatabase through OGR). Generally speaking we’ve
> found that map draw operations are substantially slower with these
> data sources than if we use Shapefiles; and that the performance hit
> is even greater with drawquery operations, especially as the size of
> the selected feature sets increases.
> We did some informal testing, both within our MapServer environment to
> compare the performance with different data formats, and also between
> MapServer and ESRI ArcIMS environments. Here are some of the results
> we came up with:
> 1. We compared MapServer performance with SQL Server ArcSDE and
> Shapefiles (with spatial indexes defined for the Shapefiles), with a
> large polygon layer representing property parcels (329870 records). To
> draw the whole layer at full extents, it took 10 seconds with
> Shapefiles, 26 with SDE. To zoom in to a small area, 0.3 seconds with
> Shapefiles, 2.2 seconds with SDE. These times are just the draw times
> reported from the debugging.
> 2. We compared MapServer performance with Oracle Spatial 9i Standard
> Edition and Shapefiles, using a polygon layer that has about 6000
> records. To draw the whole layer at full extents, it took 0.29 seconds
> with Shapefiles, 0.98 with Spatial. To zoom in to a small area, 0.28
> seconds with Shapefiles, 0.6 seconds with Spatial. We also tested
> selected and highlighting features: select 75 records (querybyrect),
> 0.5 seconds with Shape, 2.7 with Spatial; select 3000 records, 0.5
> seconds with Shape, 9.4 with Spatial.
> 3. We compared MapServer performance with ArcIMS performance using the
> same data sources (the property parcel layer with 329870 records).
> This is an even more informal test as we didn’t have access to the
> same debugging info on the ArcIMS side, so I will just say that
> comparing with Shapefiles only, the 2 platforms were roughly
> comparable; but ArcIMS speeds up a little with SDE, while MapServer
> slows dramatically with this format.
> 4. We have even more problems when we want to use the results from the
> selection in test 2 to show the attribute data to the user on a
> separate HTML form. On the ArcIMS side we can process attribute data
> quick quickly as the server sends back an XML file with the attribute
> data in it. On the MapServer side the only way we know to publish the
> attributes is to loop through each field of each returned record to
> create the HTML table. Extracting the data in this fashion is again,
> for some reason, way faster with Shapefiles as the selection sets get
> bigger – for example with the 3000 record test it took 3.2 seconds for
> Shapefiles, and 9.4 seconds with Oracle Spatial. When you add those
> times to the draw times the Oracle Spatial approach becomes
> unworkable; likewise with ArcSDE.
> So, there are some questions in all this that I’m hoping the experts
> on the list can answer: are we doing something wrong, or are these
> numbers to be expected, and if the latter, why are these other,
> supposedly enterprise type data sources so slow? Is there a better way
> to get the attributes onto a form than looping through each record,
> each field? Are there steps we can take to optimize the performance of
> Spatial or SDE with MapServer?
> I know there are lots of other users out there using Spatial and SDE –
> I’d really appreciate hearing what has worked for you.
> Finally, anticipating questions on the testing technique, I do want to
> stress the use of the term “informal” to describe these tests – this
> was not a formal benchmarking exercise. But the results bear out the
> experiences we’ve been having over months of working with these
> datasets, so while the precise times are not to be taken too seriously
> I think the general results are representative.
> Thanks in advance.
> Mark Adams
> General Manager, Ottawa Office
> DPRA Canada
> 440 Laurier Ave W
> Suite 200
> Ottawa , ON K1R 7X6
> Phone: 613.782.2326
> Fax: 613.782.2228
> Email: mark.adams at dpra.com <mailto:mark.adams at dpra.com>
OSGIS, Open Source GIS
http://www.osgis.nl
