Mapscript Re-Projection on-the-fly
Frank Warmerdam
warmerdam at POBOX.COM
Thu Aug 24 10:38:44 EDT 2006
Delfos, Jacob wrote:
> Hi Stefan,
> Yes, you do have to specify which projection each layer is in, otherwise
> when they are reprojected you will run into trouble (if it doesn't know
> where to reproject FROM, it won't be able to do i). It's not too hard,
> though.
> You should not have to recalculate the extent; it should be automatic.
> Definitely don't try to change the numbers (coordinates) without
> changing the projection (that would be bad).
> Try this:
> $newproj="proj=robin,lon_0=0,x_0=0,y_0=0"; // projection string of your
> new projection
> $map->setProjection($newproj,MS_TRUE);
> I think that ought to be all. The MS_TRUE makes it pick the best fit to
> the current extent in the new projection. Make sure your projection
> string is valid.
Jacob,
A good suggestion!
Just to pick a nit or two, I'd like to encourage people to use the "+"
syntax for projections as it avoids some quirky things with the above
approach. The plus notation would look like:
$newproj="+proj=robin +lon_0=0 +x_0=0 +y_0=0";
or as a PROJECTION block:
PROJECTION
END
Also, it is a good practice to include an explicit ellipse or datum
in coordinate system definitions.
$newproj="+proj=robin +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84";
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
