Install on Suse 10.1
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Sun Aug 27 11:39:02 EDT 2006
Matthew Perry wrote:
> Ryan,
> I noticed --with-ogr and --with-gdal point to different versions of gdal.
> Try pointing --with-gdal to your locally built gdal-config script
> (/usr/local/gdal-1.3.2/bin/gdal-config ??) and simply specifying
> '--with-ogr' without arguments.
Nope still no good, i tried using just --with-ogr and i got a different
error:
map.h:386:21: error: ogr_api.h: No such file or directory
In file included from mapfile.c:146:
map.h:1712: error: expected ‘)’ before ‘hGeometry’
mapfile.c:151:24: error: cpl_conv.h: No such file or directory
mapfile.c:152:20: error: gdal.h: No such file or directory
when i tired to remove --with-ogr from the configure command i was still
left with
I did install gdal from an rpm that i found at :
http://www.gdf-hannover.de/media.php?id=1&lg=en
could maybe there be something wrong with that rpm? when i tired to
install it from the source i ran into missing library problems but the
rmp seemed to install fine and i can use all of the gdal commands from
the command line.
> On 8/27/06, Ryan Ollerenshaw <ollerery at engr.orst.edu> wrote:
>> I have been having all kinda of trouble installing mapserver on Suse
>> 10.1 i have been able to work though most of the errors but i am now
>> once again stuck. the configure command runs fine but when i do a make
>> i get the follow error:
>> I did a locate for gdal.h and cpl_conv.h and nothing.
>> Here is the configure that i am using:
>> ./configure \
>> --with-php=/usr/share/php-4.4.3 \
>> --with-proj=/usr/local/proj-4.4.9 \
>> --with-httpd=/var/www/bin/httpd \
>> --with-ogr=/usr/local/gdal-1.3.2 \
>> --with-gdal=/usr/bin/gdal-config \
>> --with-postgis=/usr/local/pgsql/bin/pg_config \
>> --with-curl-config=/usr/bin/curl-config \
>> --with-threads \
>> --with-geos=/usr/local/geos-2.2.1/tools/geos-config \
