map.removeLayer(index) -- C#
    Zhonghai Wang
    zhonghaiw at GMAIL.COM
    Mon Aug 28 10:27:41 PDT 2006
Hi Tamas,
I am using the binary downloaded here:  (MS4W 2.1)
http://www.maptools.org/ms4w/index.phtml?page=downloads.html
I noticed that there is a new beta source version, but I do not compile it
yet.
I do not tried with the other hard coded layers, but I think it may have the
same problem, here is the code caused the strange problems:
1. this works well with index:  -- insertLayer
objMapping.insertLayer(objMapTemp, shapeRegionLayer,
objMapping.getLayerIndex("France_Departements", objMapTemp) + 1)
-- the last parameter is the index value I used to insert the inline layer
"shapeRegionLayer", the layer "France_Departements" is a hard coded layer in
mapfile.
2. but I am not so lucky enough with this one: -- insertLayer
objMapping.insertLayer(objMapTemp, shapeCommunesLayer, 11)
-- here only the index value -1 works, any other value will cause exceptions
like: msFreeHashItems(): hash table error.
3. this does not work:
Dim tempLayer As layerObj = objParentMap.getLayerByName(strLayerName)
Dim intIndex As Integer = tempLayer.index()
objParentMap.removeLayer(intIndex)
I will test the removeLayer method again with a hard coded layer.
Do you have any other ideas to remove a layer from the map object?
Thanks
Zhonghai
On 8/28/06, Tamas Szekeres <szekerest at gmail.com> wrote:
> Zhonghai,
> There was problem with insertLayer according to
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1838
> The problem was recently fixed (4.10.0-beta1 should contain the fix).
> Is the removeLayer problem also exist for the other layers? (not for
> the dynamically added layers)
> Which mapserver version are you using?
> Could you include a code sample according to the problem?
> Tamas
> 2006/8/28, Zhonghai Wang <zhonghaiw at gmail.com>:
> > Hi guys,
> > I am trying to remove an inline feature using the map.removeLayer
> (index),
> > but it seems that this method does not work. The inline feature layer is
> > created on the fly, not in the mapfile hard coded. Does anyone ever used
> > this function successfully? There may also be some problems with the
> > map.insertLayer(layerObj, index), only map.insertLayer(layerObj,-1)
> works
> > for me, I can not specify the index.
> > thanks for any hints to solve my problem.
> > Zhonghai
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060828/c319a408/attachment.htm>
More information about the MapServer-users
