Using CSharp Mapscript with VS2005 and .NET 2.0
Jim Bartol
jbartol at MMM.COM
Mon Aug 28 17:08:17 EDT 2006
I have been experimenting with the latest version of MS4W V2.1 via a web
browser, and learning some of the basics about how MapServer works. I am
now trying to use CSharp Mapscript to access MapServer directly from a
WinForms application. I understand that the MS4W binaries have been
compiled for .NET 1.1, and that there are some issues with running them
against .NET 2.0 as described in
http://mapserver.gis.umn.edu/docs/howto/mapscriptcscompile. My
*.exe.manifest file shows a reference to the CRT as described in section
3.1 of this website, but I still get a runtime error "The type initializer
for 'mapscriptPINVOKE' threw an exception" when creating an instance of a
MapServer object (e.g., mapObj map = new MapObj("mapfile.map"). Both
mapscript.dll and mapscript_csharp.dll are in my bin/debug directory.
I came across a previous post from David Lother who may have worked through
a similar problem. Any suggestions as to what I might be missing in
regards to building a WinForms app with CSharp Mapscript? Could there be
something I've overlooked regarding manifest files? Can I use MS4W V2.1
with .NET 2.0, or should I rebuild the binaries using the VS2005 compiler?
Thanks for any help you can provide,
