Compiling Mapserver with WCS
B Tuttle
funkbucket at GMAIL.COM
Wed Aug 30 16:23:18 EDT 2006
Hi-
I'm still a little new to mapserver and I have a build of 4.8.3
running wms just fine. I'd like to add WCS and WFS though. I think
that I didn't compile with WCS and WFS included based on the
following:
[root at localhost cgi-bin]# ./mapserv -v
MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
I am correct in thinking I need to recompile with some extra flags to
get WCS and WFS functinong?
If so does the following look like a reasonable way to go about addidn
WCS and WFS support:
./configure \
> --with-proj=/usr/local \
> --with-geos=/usr/local/bin/geos-config \
> --with-ogr=/usr/local/bin/gdal-config \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-postgis=/usr/local/pgsql/bin/pg_config \
> --with-curl-config=/usr/bin/curl-config \
> --with-httpd=/usr/local/apache2/bin/httpd \
> --with-php=/usr/local/php-5.1.2 \
> --with-wcs \
> --with-wfs \
> --with-wfsclient \
> --with-wmsclient \
Finally, am I correct in believeing that I can just build mapserver
again and all the other items I installed (gdal, ogr, proj4, postgis,
etc.) can be reused as is?
Just want to be sure I am going about this correctly before going the
install again.
