AW: [UMN_MAPSERVER-USERS] Transparent raster layer
Pleyer, Walter
Walter.Pleyer at LFRZ.AT
Thu Aug 31 08:28:47 EDT 2006
Thanks, Flavio!
The TRANSPARENCY Parameter worked - kind of.
Now when I set the TRANSPARENCY parameter of the layer object to varying
values, the resulting image gets paler or less pale, but unfortunately
not transparent in the sense, that I see the underlying image through.
Do you have any ideas, hints?
Cheers
Walter
> Example:
> LAYER
> NAME "Switzerland Relief"
> MINSCALE 100000
> TYPE RASTER
> TRANSPARENCY 50
> STATUS ON
> DATA "Relief.tif"
> PROCESSING "RESAMPLE=AVERAGE"
> PROJECTION
> "init=world:CH1903"
> END
> END
